hey another newbie joins the forum.
Hey guys. Jus joined after I.was pointed in this direction by some1 from mk3oc (astra forum). Bought myself a cavi 1.8 8v hatch. Needs very little work. Has 115k on clock. Has an idle issue. Believe this to be down to it drawing air from vac control valve thingy at back of engine bay.
Re: hey another newbie joins the forum.
Welcome to the forum.
C18NZ I take it? Yep worth checking the vacuum hoses and breather hoses. EGR valve might need a clean out too. Stick around.
Andrei.
Andrei.
Need to know which engine, or at least what year, to help determine what you have under the bonnet? A description of the idle fault would help too.
Welcome to the site
Welcome along
I am also on Astra mk3oc.com, have the green 2.0i on the other cars section and a Wip on here too
It's a 1.8i 8v expression on a 95 n reg
C18nz engine then. Do you mean the tank vent valve that has a hose back to the servo pipe and leaks air into no4? If so replace it.
Welcome to the site.
Hi and welcome to cavmk3oc! Enjoy your stay, hope you're enjoying your new ride
Welcome mate
Look forward to some pics!!!
- John Owens
Hi Allan , welcome to the site mate
