New to club
New to club
Hi guys my name is Allan . The proud owner of a 1993 facelift v6 cesaro. Had it for 17 years without problems. But now I have a problem with the abs. I’m in central Scotland
Re: New to club
Hi Allan,
Welcome to our little forum,
Please fire away any questions that you may have regarding the ABS.
If yours is the early version (unlikely as you have a facelift cav), then the ABS control module is next to the passenger seat under a hump in the carpet.
If your's is the later version, then it is the module in the engine bay up between the battery and suspension turret.
This later type can usually be diagnosed using the paper clip test on the appropriate pins in the diagnostic plug.
95% of failures / errors are caused by the front ABS circuits.
1 - rusted / cracked toothed rings on the front CV joints.
2 - dirt build-up between the teeth.
3 - Displaced pick-up due to damaged location clamp.
4 - Damaged cable that has been rubbed by a tyre.
Rear end circuits would be damaged or corroded rear pick-ups, connector pins or dodgy wiring.
I hope that gets you started.
Nice model of car, by the way
Re: New to club
Here is the fault diagnosis blurb.
This is the general listing for the ABS Modules
(Courtesy of Andy Kirwan's Technical site - updated and edited)
To carry out a flash code diagnostic of the ABS system, short pins A and K on the diag plug and then turn on the ignition (engine not running).
If there are any stored fault codes, then the ABS Tell-tale light should flash out a two digit numerical sequence.
Early models which have the old ABS system where the control unit is located at the side of the passenger seat in a lump in the carpet do not usually have this fault code facility.
Check whether the diag plug has a wire at location K.
CODES.
16 LH Front Solenoid ( Relay & Connections )
17 RH Front Solenoid ( Relay & Connections )
18 Rear Solenoids ( Relay & Connections )
19 Solenoids Relay Circuits
25 Faulty Sensor toothed Ring
35 Pump Relay Circuits
37 Stop Lamp Switch ( Pedal Switch )
39 LH Front Speed Sensor ( Air Gap & Operation )
41 LH Front Speed Sensor ( Resistance & Connections )
42 RH Front Speed Sensor ( Air Gap & Operation )
43 RH Front Speed Sensor ( Resistance & Connections )
44 LH Rear Speed Sensor ( Air Gap & Operation )
45 LH Rear Speed Sensor ( Resistance & Connections )
46 RH Rear Speed Sensor ( Air Gap & Operation )
47 RH Rear Speed Sensor ( Resistance & Connections )
48 System Voltage High/Low ( Alternator & Battery )
55 Faulty ECU
CODES.
55 Faulty ECU
Re: New to club
Hi & welcome Allan
Good to hear there's another one on the road
Re: New to club
Hello & Welcome
I have a 1.8 Motorsport / Cesaro which does not have ABS, which I use as my everyday car.
