towing info
towing info
looking for towing info of my cavy and nose weight limits if anybody can help
2.0 16v redtop saloon
cheers scott
cheers scott
Re: towing info
Are you going to be towing it on a trailer? or is the cav going to be towing a trailer?
Re: towing info
im going to be towing my caravan (fingers crossed) it weighs 1250kg loaded
cheers scott
cheers scott
Re: towing info
I think 1300kg rings a bell, I looked at this for mine a while back. It might be in the handbook, I will try to remember to look when I get home.
Re: towing info
Researched this again, unless the chassis plate states a lower max trailer weight then you can basically tow up to the weight of the vehicle, but it is recommended that you only tow 85% of the weight of the vehicle. Handbook states 1205kg for c20xe and another 30kg if it has AC. Nose weight is 75kg. Pushing it a bit if your van is 1250kg laden, but within as long as you are careful with loads. If you aren't experienced at towing it might be wise to have a practice with a bigger car or smaller caravan first. Caravan sales outlets have a computerised check these days and will not/are not allowed? to sell a van to someone that is going to tow it with a car that it shouldn't be attached to. These guys will probably be able to confirm for you.
NB. Myself and the forum administrators take no legal responsibility for the accuracy of the information given above. If in doubt please get it checked at a caravan dealer.
Re: towing info
I used to tow a swift challenger 450/5 with my V6 no problem.Unladen weight was around 820kgs.
Seemed to remember i'd aim for around 50kgs nose weight.
As Planetc says check with a caravan dealer about what is safe and legal.
Re: towing info
My old man as a well seasoned caravanner used to quite happily tow over the weight of the car but I think there are more stringent rules these days. I do know there is a maximum for the vehicle on the chassis plate that you cannot legally go over, as my zafira is severely crippled in this department at only 1050kg. There is also a gross train weight which is the laden total of both car and caravan.
Re: towing info
take a look on the vin plate on the slam panel it should have 4 different weights on it in a list, so it will look something like this
1650 - vehicle weight
2950 - gross train weight (vehicle and loaded trailer so in this case 2950 - 1650 = 1300 so your loaded trailer can be up to 1300kgs)
840 - front axle weight
820 - rear axle weight
this is what mine states on my c18nz gls hatch
so i can tow 1300kgs but i don't know how to work out the nose weight
hope this helps have a look on your slam panel at your vin plate and it will tell you your specific weights as they may differ from mine
Re: towing info
thats 75kg, its in the handbook, mine is an 1800 too, and I remembered 1300 kgs so that means I have a better memory than I thought!Rage wrote:
Re: towing info
another can of worms opened lol cheers for the help guys u can tow up to your kerb weight of your car but also add on 75kg for driver as well so ive been told
my mondeo mk3 v6 is on its last legs so i need a new car anyway but was hoping to tow my van with the cav looking at going to cornwall in the summer (long way i know from sunny shotts lol) might nip into vauxhall to see if they can help
cheers scott
![Scratch :scratch](./images/smilies/icon_scratch.gif)
cheers scott
Re: towing info
just had a look in the rain
top number is 1710
number underneath is 3010
1300 kg towing weight max that will be breaked too so its about 95-97% of my 1250kg weight of my van
scott
top number is 1710
scott
Re: towing info
I pull a 900kg caravan behind my 2litre 8v gls. It does 70mph ok, but runs at about 95° constantly. Also, its really thirsty when pulling. I've never pulled a van before, the brakes are interesting! I had someone pull out on me, i barked as hard as possible to miss them, my abs worked but the caravan skidded to a halt!!
1995 CDX 16v
Re: towing info
i recently towed a car transporter with a fiesta on it and the brakes were interesting there aswell lol. i just had trouble because of how low she is having the trailer on made her scrub the rear tyres.
- Kevwaggy
Re: towing info
Depending on when you passed your test allows alters how much you can tow...
"You offer someone a sincere compliment on their moustache and suddenly she's not your friend anymore"
I've decided I would really like a sex change, preferably from 'none' to 'absolutely shitloads'
Re: towing info
kevwaggy has a point need a pre jan 1997 test to tow any thing more than a halfords trailor!
as for weight i always thought 80% to a max 0f 100% of the cars unladen weight weight is allowed
when it weighs more than the car the caravan could take control![Thumbs down :tdown](./images/smilies/thumbsdownsmaller.gif)
