A major job, or time saving idea?
Hi,
I've found a Cav in a local scrappy which has had a front end crash. The rear arches are really good, i mean really clean. The cars only done 70k. I was thinking of cutting the rear arches out to weld into mine to replace my rusty ones. I was thinking of cutting from the sill, all the way around and half way in the wheel well, if that makes any sense! Is this more hassle than either getting mine welded or buying repair panels? He has said i can have both sides for a 10er if i remove them myself.
Any ideas?
Thanks
Any ideas?
Thanks
1995 CDX 16v
Re: A major job, or time saving idea?
Id just go and buy 2 repair panels. You could cut them off and find tons of filler in them,.
- Chip Pan Dan
ive got two brand new rear archs
is the car beyond repair? might be easier to shove your front end panels on it?! aftermarket arch repair panels are cheap and easy enough to get hold of, albeit not a perfect oe fit without a lot of fettling.
Its well gone Front drivers wheel is pushed up into the door. Brutal! Thanks for all the advise, i was hoping it was a cheap fix.
Ta
Ta
1995 CDX 16v
Mart this ant my old cavalier???
No mate. Light red 94 with phase one front bits?? What ever it hit, it went in hard.
1995 CDX 16v
Take the rear glass out, cut at the back of the sill, 3-4 inches in
Drill out the spot welds under the glass.
Cut up the inside of the inner arch
Unpick / drill out the welds around the rear light cluster
And cut the panel along the C pillar about 6 inches up. Least you will have enough metal to play with then.
Get a plasma cutter if you wanna go down this road
They are fun to use. See if scrappy has one and is willing to cut up the car for you.btcctroy wrote:Get a plasma cutter if you wanna go down this road
Very much doubt theyd have a plasma cutter. Most of the time they'd use oxycetaline to burn it outEnvoy CDX wrote:They are fun to use. See if scrappy has one and is willing to cut up the car for you.btcctroy wrote:Get a plasma cutter if you wanna go down this road
