Bulkhead soundproofing!
Took the lower half of the soundproofing off the SRIs bulkhead today and wow, Its super clean..but it was soaking wet and that cant be good.
Have you all checked yours?
Re: Bulkhead soundproofing!
You mean the exterior or interior? Exterior is always damp, it picks up water from wet roads and moisture from damp air. Bit like leaving a carpet outside during winter. On my old auto, I could physically rinse the bottom of it Not a good idea, water + metal = you know what...
Yeah, The outside one. I bet some cavaliers have some really bad rot under that lot
At the last MOT my V6 picked up an advisory for corrosion on the bottom of the bulkhead. Dread to look at it now!
Removed all of mine years ago, as all others it was soaked.
ripped all mine off after i had to have the drivers side powersteering mount repaired due to the stuff.
- vauxhallnutter
Get it treated bud before you have to start having it welded!Cavalier342 wrote:At the last MOT my V6 picked up an advisory for corrosion on the bottom of the bulkhead. Dread to look at it now!
Can't even drive it at the moment, and have no access underneath...
- joe cavalier sri
I removed mine when I converted to xe from xev super clean under there but treated it to keep it that way too.
Likely it will already be screwed.vauxhallnutter wrote:Get it treated bud before you have to start having it welded!Cavalier342 wrote:At the last MOT my V6 picked up an advisory for corrosion on the bottom of the bulkhead. Dread to look at it now!
It's another common place where they go.
Probably... I'll take a look underneath when I next get a chance.
- vauxhallnutter
You can see the bulkhead from under the bonnett!Cavalier342 wrote:Can't even drive it at the moment, and have no access underneath...
Have you tried looking at the bottom of the bulkhead from above the engine in a V6?
You can see it from the top, But not on the v6 haha
- vauxhallnutter
Ah yes, sorry I forgot it was a V6 me bad sorry!Cavalier342 wrote:Have you tried looking at the bottom of the bulkhead from above the engine in a V6?
- Metallicav
What difference does removing it make sound wise inside the car?
