can someone with epc help
- beermonsterblack
im after the part numbers for the bodykit clips on my gsi but I cant find the the little clips for the top of the hockey stick
Well, thank you, Mr. Bandit. And as the pursuer, may I say you're the goddamnedest pursuee I've ever pursued
Re: can someone with epc help
Not quite sure what you mean by Hockey Stick, but here is a listing of th GSi trims and clips....
14
(90330238) (1 64 489)
PANEL, STONE PROTECTION, FRONT, RH, PRIMED (NLS.- NO REPLACEMENT PART)
14
(90330237) (1 64 488)
PANEL, STONE PROTECTION, FRONT, LH, PRIMED (NLS.- NO REPLACEMENT PART)
15
(90330270) (1 64 687)
FLAP, FRONT, RH, PRIMED (NLS.- NO REPLACEMENT PART)
15
(90330269) (1 64 686)
FLAP, FRONT, LH, PRIMED (NLS.- NO REPLACEMENT PART)
16
(90330284) (1 64 689)
FLAP, REAR, RH, PRIMED (NLS.- NO REPLACEMENT PART)
16
(90330283) (1 64 688)
FLAP, REAR, LH, PRIMED (NLS.- NO REPLACEMENT PART)
17
(90330252) (1 64 491)
PANEL, STONE PROTECTION, REAR, RH, PRIMED (NLS.- NO REPLACEMENT PART)
17
(90330251) (1 64 490)
PANEL, STONE PROTECTION, REAR, LH, PRIMED (NLS.- NO REPLACEMENT PART)
DOOR PANEL STONE PROTECTION - 2000,GSI,TURBO
18
(90330202) (1 28 196)
MOULDING, STONE PROTECTION, FRONT DOOR, RH, PRIMED (NLS.- NO REPLACEMENT PART)
18
(90330201) (1 28 195)
MOULDING, STONE PROTECTION, FRONT DOOR, LH, PRIMED (NLS.- NO REPLACEMENT PART)
19
(90330216) (1 28 198)
MOULDING, STONE PROTECTION, REAR DOOR, RH, PRIMED (NLS.- NO REPLACEMENT PART)
19
(90330215) (1 28 197)
MOULDING, STONE PROTECTION, REAR DOOR, LH, PRIMED (NLS.- NO REPLACEMENT PART)
24
90503824 1 64 890
BUTTON, PUSH, STONE PROTECTION TO SILL PANEL
28
90033713 1 64 361
RIVET, BLIND, STONE PROTECTION TO SILL PANEL
14
14
15
15
16
16
17
17
18
18
19
19
24
90503824 1 64 890
28
90033713 1 64 361
- Attachments
- car parts gsi.JPG (19.88 KiB) Viewed 147 times
- beermonsterblack
the little clip that holds the top of part 17
Sorry my friend.
As you can see from the images,
Even EPC does not show this clip or a part number for it.
