Anti-roll bar diameter (Rear)
Anyone know the diameter of the rear roll bar for the 1.8 model as I need to get bushes? I see different measurements on ebay offerings like 14mm, 15mm and I measure mine and they look to be 16mm. Likely expanded a wee bit due to crust and swelling overcoat but not too sure what the actual measurement should be?
Re: Anti-roll bar diameter (Rear)
When I fitted new rubbers to my 1994 C18NZ Cavalier, I fitted the following parts.
Rear Anti-roll bar centre rubber bearings -
90 236 352 at £6.38 each from Lookers Vauxhall in Ellesmere Port.
Rear Anti-roll bar end rubber bearings -
90 236 353 at £2.11 each from Lookers Vauxhall in Ellesmere Port.
So nice prices from the main dealer.
Prices were correct in spring / summer 2016.
The way I chose my centre bearings, was to look at the writing on the rubber bush.
If you cannot see the 8 digit part number, then you may have a single digit on yours.
Somewhere between 1 and 4 springs to mind.
Can't remember if mine said "2" or "4".
But on EPC and Ecat24, there should be mention of the single digit code.
Cheers robsey will check those numbers out see what i can get. Yours should be same as mine.
