I have been quiet on this thread for a while... still been bumbling along with various things.
Things have been quite busy on the unit front...
Multiple jobs on the go at present.
Recent work has been body repairs on a Cavalier, coming to a thread near you soon.
Now drawing to a close, but it has given me the mental boost to start preparing to fix my own Cavalier.
There was also a Nova...
New wings, side repeaters and aerial to fit.
Not too shabby if you ask me.
As usual, I left the bodywork to the expert, I just assisted with the fiddley bits...
Current job is....
Well, lets see if any clever clogs can spot the car...
Or what is left of it.
The car has been stripped for a full respray.
As usual, I volunteered for the fiddley annoying jobs, whilst Troy does the precision stuff.
On this car, there is something called a 'belt line'.
This needs to be removed to allow a proper paint job.
The issue here is the need to remove the soft-top, and then a rain guard from the rear of the cockpit.
Thirteen 10mm nuts (M6) across the curved periphery followed by countless trim clips, four peg bolts and six 14mm nuts to get the soft-top out.
Followed by another eight 10mm nuts to remove the belt line. About an hour, all in.
Quite a respectable time.
Next job to get the alternator out.
Something sounds really rough, and the engine felt very tight during cranking.
A couple of hours moving an engine mount and trying to loosen the alternator bolt ensued.
Eventually the bolt loosened, but not before shearing off it's tip.
It is assumed the previous owner's mechanic had tried to knock the bolt through resulting in a peened over thread, no way that was coming out, without drilling...
My job for tomorrow night no doubt.
Not sure what it is on this model, but the engines all look like a mass of rust, and white powdery aluminium oxide.
We have come to the conclusion that it is the water pump, not the alternator causing the roughness.
There is some water seapage at the front of the engine.
Looking at how rubbish the previous garage must have been, the plan is to do a full timing belt and tensioner change - along with a new water pump.
