Gutted, failed waterpump on my SRi 8v
dandemann8
Post by dandemann8 »
As the title says the waterpump has failed and I'm not sure if the car is worth repairing :cry . I've owned the vehicle for 8 years with no problems untill this happened. So really I'm looking for suggestions as what to do next i.e scrap, sell it as sale or repair or repair it myself? The cars only covered 65K approx and in A1 condition inside and out apart from the engine that is :cry .Any help and advice would be very much appreciated.
diddygsi
Re: Gutted, failed waterpump on my SRi 8v
Post by diddygsi »
just replace the water pump and timing belt there only cheap and easy enough to do
dandemann8
I've been told that the head is possibly gone so I would be spending money for nothing, not being mechanically minded I'm not sure what to do.
It may be time to say goodbye :cry and look for a replacement.
TurboSteven77
Post by TurboSteven77 »
has it got gunk on oil cap ?
plus 8vs are boom proof as paul said above changge water pump and belt
Always worth putting a belt and pump on an 8v. Worst case would be a set of valves, but often only a couple and sometimes they survive without valve damage. Think I only ever saw one that had damaged guides. If the car is good it's worth spending the money. Even if the engine overheated rather than throwing the belt, I'd still go for it. Where are you, maybe someone here can help you?
dandemann8
No gunk in the oil cap.
I'm located in Stoke on Trent about 1 mile from Junction 15 of the M6.
Peanut_119
Post by Peanut_119 »
agreed the 8v engine are bomb proof, my e16se (1.6 gsi) the cam seized on that and the valves was fine, change cam and carried new timing belt and away it went :D
dandemann8 wrote:No gunk in the oil cap.
quite a few members in that area, fingers crossed someone will offer up some help
dandemann8
Just like to say thanks for all your replys but after carefull consideration I'm afraid I'm going to scrap my car as I can't spare any cash on the possibility the repair is unsuccessfull, so I will be ringing around to see what scrapyard's are willing to give me tomorrow. :cry
diddygsi
Post by diddygsi »
mate dont scrap it these engine DO NOT DAMAGE VALVES
get the pump and a belt 50-60 pound tops and il fit it for you if you want
im not far from you and im up that way alot of the time anyway
dandemann8
diddygsi wrote:mate dont scrap it these engine DO NOT DAMAGE VALVES
Thanks for the offer, it was run for about a mile or so before it gave up, the head has been removed so I'm not very hopeful with what I've been told.
Worst case is a head skim, a flush of the oil and water systems with new belt and pump and turn the key... these engines are fantastically tough little buggers. The head HAS to be removed to check gaskets and potential damage.
The worst realistic case is a warped head and blown head gasket, you've probably cooked the block nicely running for a mile or so with no water, but it ran...
dandemann8
Cheers all but decided it's got to go, it's been a great car to own and drive over the past 7 years but it's time for a change so will either list on Ebay spares or repair or ring around the scrapyards.
Can you list the Ebay link here please, someone may be interested.
dandemann8
Squig wrote:Can you list the Ebay link here please, someone may be interested.
Am I OK to do this as I don't wish to break any rules :?: :?:
I agree, at least put the parts on offer as the demand is there.
Andrei.
ebay links are fine.
dandemann8
Will get some pictures tomorrow and list on Ebay and then provide the link.
