0-60, just curious.
0-60, just curious.
Roughly speaking, what are your 0-60 times? Obviously not trying to start a "boy racer" thread but just curious. Got a 10.18 today on my stopwatch on an empty stretch of road in the countryside. Did two runs, that was the mean. That's in my standard 18SV with 1/4 tank.
Andrei.
Re: 0-60, just curious.
There's an Android app for measuring this, probably more accurate.
What the hell is that?
The spec for the 1.8 is 11 secs. So your car is probles right due to the fact that the speedo never reads true.
The v6 is 7.3 and according to a tuning website I was on. they recomended fiting a lightened fly wheel and f28 as this was ment to reduce the time by 0.5 secs.
But the only way to get a true 0-60 is with specialist equipment.
I do understand the speedo reading issue, but without specialist equipment I took down the times as it was. So basically it's as it should be, so that's good then. Was seeing how well the carburettor responded to different temperatures as well. Good to know. :thumb
Re: Re: 0-60, just curious.
Cavalier342 wrote:What the hell is that?
http://www.codesector.com/speedview.php
There you go chap, some reading for you.
Cool. I still don't get what an android is though. I do know that GPS is ultra-accurate however.
V6power
Post by V6power »
android is an operating system for a smart phone
If in Doubt.......Flat out!
right... something i'm never gonna get but thanks for explaining it :thumb
Cavalier342 wrote:Roughly speaking, what are your 0-60 times?
Dunno, faster than you?
mr v6
Post by mr v6 »
my old 1.8 speedo was well out.to get a true speed you need to use a sat nav.for example coaches are restricted to 63 mph but when i matched a national express coach speedo sd 70 sat nav was 63 as should be.definetly need timing gear for a true 0 to 60 reading!
:lol: Obviously, I wasn't after competition lol
blackv6
Post by blackv6 »
mine does 0-60 in about a fortnight :thumb
SRi_stu
Post by SRi_stu »
my 2.0 ecotec feels quicker than it probably should be :lol:
never fails to impress me when i plant my foot and it takes off, i nearly didnt buy it when i got disappointed looking under the bonnet :lol:
HAIRIBO wrote:The spec for the 1.8 is 11 secs. So your car is probles right due to the fact that the speedo never reads true.
sounds right I got 6.9 with the above mods, but that was emma hitting the onboard timer as I called it.
My ecotec was a fast car when I was 21. (10 years ago), that dose make me feel old now. It just could never handle the speed in the corners. Once I u rated everything it handled really well, and the power then started to feel too little lol, thats why I stuck a 200BHP v6 in it. Now its faster.
I loved the car when it was an ectotec, the engine just wasn't strong enough to handle too much abuse.
I remember 18 years ago in my dads 1.8 LS I thought that was a rocket ship. as it had injection! But the again....... it was compared to the Montego 1.6 He had just sold.
I once read in a magazine a CDX16v cav got a 0-60 in undre seven secs. It was at a santa pod day, that MAxpower. or Fast car covered. It was a genuine time as it was fitted with all the high tech stuff.
The car was standard and the driver said. "It was a flook"
There was a few escort cossies doing it in under 6.
But that was back in the days were the modified car mags were full of cossies.
So I guess its possible to get a better fiqure that tat stated by vauxhall, if the conditions are right.
And lets face it. A second is not a very long time.
You could loose or gain that in good/bad gear changes.
DiplomaXE
Post by DiplomaXE »
mines not quite standard, also has the ridiculous gear ratios in it and were looking at about 60 in 2nd quite easily, in about 7 secs. 110 in third is the on the rev limit and it's at 140 in 4th. wont pull any more in 5th.
on a rolling road its been up to the limiter in 5th though, graph showed 170 mph odd iirc.
iancav6
Post by iancav6 »
On my last Santa Pod visit,the cav did the 1/8 mile in 9.3 secs at 76mph and the 1/4 in 14.4 at 97.
That equates to 0-60 in around 6 secs.
iancav6 wrote:On my last Santa Pod visit,the cav did the 1/8 mile in 9.3 secs at 76mph and the 1/4 in 14.4 at 97.
what engine it that pal
iancav6
Post by iancav6 »
3 litre V6 with a load of mods.
I'll buy you a sandwhich if you Make me a set of exhaust manifolds.
iancav6
Post by iancav6 »
I'll buy you a sandwhich if you Make me a set of exhaust manifolds.[/quote
Roast beef salad with horseradish sauce please :D
This is the run summary from that day,12 runs all within 0.4 secs
i have never seen a v6 cav do under 15. good work
Kevwaggy
Post by Kevwaggy »
iancav6 wrote:I'll buy you a sandwhich if you Make me a set of exhaust manifolds.[/quote
If that's the going rate I'll make you a whole platter! (cut into little triangles 'cos we all know they taste better)
Now that is a tight set of times.
What box are you running at the moment?
