whining noise and not from passenger seat :)
whining noise coming from speakers, rises with revs and volume isn't affected by stereo volume... what could cause this didn't do it before fitting new cams... i'm confused
Re: whining noise and not from passenger seat :)
If its coming through the speakers, could it be related to alternator?
I'm assuming you've turned the radio off to see if the noise is still there?
Is it a high pitched sound or just a buzzing whinning sounds?
doesn't exist when stereo is off isn't related to the stereo volume and changes pitch with engine revs
Youve got back feeding from the alternator you need a suppressor
please expand on that a little gaz... where from/ what do they look like, etc
Its a little box that bolts to the alternator and shuts up the whining, should pick one up at the autofactors for not much less than a tenner
or the inline type http://www.maplin.co.uk/free_uk_deliver ... _33180.htm
what causes this? cos it wasn't there before PVS...
test the out put on the alternator. ?Squig wrote:what causes this? cos it wasn't there before PVS...
how and what am I looking for?
Squig wrote:how and what am I looking for?
Test it with a multimeter, testing the output to see if its higher than normal (should be around 14v if I recall) if it is - overcharging might cause this issue.
willcheck this this weekend and get back to you guys
have you got your phono cables next to the amp power feed?
damn! I know what is causing this now... the only change I made that could cause this is the second amp so yes I had to route the power cables under the pass side plastic sill cover. I think the second amp is causing flux interferance.
Cheers gaz... will reroute the power cables this weekend...ish
just read the title of this thread......................emma you have my permission to hit him. cheeky swine he is, be summat gaz would say
hope youve sorted this out now squigglett
