dash lights doing strange things lol
strange one
no keys in ignition
turn side lights on
then turn right indecator on
then the all dash lights come on, turn indecator off they go off etc
any ideas peeps? got me pickled tbh
no keys in ignition
turn side lights on
Re: dash lights doing strange things lol
One of two things.
Either your indicator stalk is buggered or you headlight switch. I'm going with stalk tbh.
Just changed mine Cos it was doin funny things .
hmm il try a diff stalk tomoz iain
can you buys them new still ?
pie mate just get one out of a mk4 astra, thats what i fitted, they feel much better than the older type, and saves you £15 odd posted .
the same style are they iain?
right problem still there
changed:
stalk x3
light switch x2
any more ideas ?
thanks
changed:
stalk x3
light switch x2
any more ideas ?
thanks
Sounds like something is shorting out. perhaps try removing the indicator relay, pop it back in, see if it helps.
On the later models, with the ignition off, the indicators act as parking lights, so there must be some sort of relay that controls that... Maybe that's at fault? Can't really suggest anything else...
hmm i think the gsi got parking lights ??? my j plater has
were would the indecator relay be fella?
if i pull indicator relay out
problem is till there
In the fusebox I presume
ya it was lol
also seen a bunch of relay's above the fuse bok behind light switch panel
They'll be for some of the toys you get in a GSi. Did you try cleaning the pins on the relay?
no pins looked of imo buddy
What?gsi pie wrote:no pins looked of imo buddy
imo = in my opinion
sorry
sorry
No the first part... the pins look of?
Or did you mean the pins look ok?
meant ok buddy
also noticed my white gsi dont have parking lights?
I thought it was only the facelift models that had them, my facelift auto does but my early manual doesn't... It's either that or it's model-specific?
my 91 j plate has parking lights tho hmm strange
wounder if this could be the problem ??
mines got parking lights
Bad earth somewhere, or a fuse blown and causing a back feed, you already covered my other possible suggestions. Even a multi plug with a green terminal in it can cause this type of problem.
In fact, look at the rear lights perhaps, if there were a bad earth there then the indicator may back feed and do the dash lights via the sidelight circuit?
Or are we talking ignition lights coming on?
