C25xe ecu operation
Posted: Fri Feb 22, 2013 6:40 pm
by Deegte
Think I'm having a problem with my ecu at the minute took it off to find a couple of the pins corroded. Looking to know is there anyway to test a ecu to find out if it has been damaged. Getting a replacement in Northern Ireland non key coded is hard enough.
Re: C25xe ecu operation
Posted: Thu Apr 25, 2013 7:48 pm
by 3.0cav.v6
There is companys like ecu doctor were you can send them to be checked but they are costly just for them to have a look if i can remember right before they even look to repair it
Posted: Sun Apr 28, 2013 2:59 pm
by humbucker
Your best bet is gonna be swap it out with a known good one. Thankfully V6 ECUs aren't that costly if you can find someone stripping a car.
