Fitted an aftermarket alarm to my silver Cav yesterday and i decided to use the alarm wiring behind the glove box which all went well until I came to connecting the remote central locking up. There is a brown/red for lock and a brown/white for unlock but neither of them do anything so I have had to run the wires from passenger side to drivers side and connect them in the drivers footwell near the C/L unit. This is ok but I would have much rather connected everything at the same place!
Question is are these wires for this purpose or are they for something else? I will have a study of the wiring diagrams when I get chance but wondered if anyone had a quick answer.
Alarm wiring behind glovebox
- vauxhallnutter
Re: Alarm wiring behind glovebox
The lock and unlock are black/red, bkack/yellow. The brown ones probably feed from the central locking to arm and disarm the system as it is triggered by the locking system rather than the other way around. You will find them in the harness that runs above the glove box, because that Is where I used to fit the remote add on for the factory alarm. Probe anything black with a red or yellow trace with a test light connected to earth, when you find the right ones the locking system will cycle
Usually find the 3 together, black wires one with red, one yellow and one blue trace. The blue deadlocks.
- vauxhallnutter
Ok cheers for that will take a look. I was just going on the colours that i normally connect to in the drivers foot well
