Help with centre consol/VDO gauges
In the cubby hole that should have the VDO gauges in there is this plastic shelf that I found I can move about half an inch backwards, it clearly was designed to be removed but after some pushing and wiggling I cannot find how to remove it - has anyone else managed this?
Re: Help with centre consol/VDO gauges
You don't need to remove it to fit the gauges mate, just drill a hole in the back of the unit to run a wire through. Then remove ashtray and get your fingers in there to guide the wire through.
Cheers 'Dre. I was thinking about removing it completely to help with access to rear of radio and the possibility of running so e extra lighting up the back for the heater panel...all just speculation at the moment.
That's too weird, my boss's mate called me that the other weeklowrider dave wrote:Cheers 'Dre.
Glove box out, reach round and give it a tug, clearance is scarce though as the heater box is fairly close behind that cubby.
Cheers, I'll give it another go - my back is killing me after all this grovelling about.
lowrider dave wrote:Cheers, I'll give it another go - my back is killing me after all this grovelling about.
Reach arounds AND tugs... don't get me started
You're homo-erotica collection must be taking a bashing again is it Andrei?Cavalier342 wrote:Reach arounds AND tugs... don't get me started
No comment.
I took it out in my purple cav... Had to take half the dash out to get it out decently...
In the loon I just drilled a hole as we did with Andrai and mikes...
Get a metal coat hanger or garden wire to help with routing wires...
Should be all good
Should be all good
Spent far too much time destroying it with the drill and snapping into bits to remove it. Now I have a nice easy hand reach for any behind fascia work, especially when it comes to installing my new radio.
If I didn't have to change speedo, gaiters and bulbs, and modify the radio housing to secure a short cage I would have gone down your route (especially if I'd known what was involved at the time !)
I'd probably run round the inside edges with a dremel and the little cutting disks
viewtopic.php?f=15&t=14064&hilit=+tray
