Starter's had an odd labored whine to it when starting for a week or so now. A couple days ago with the engine warm, she wouldn't start at all. Just a sloooow crank, as if the battery was completely empty. My brother rode in to help again and towed her started, after which I went to have the alternator checked. 14.54V at idle. Got home and put the brand new battery on the charger overnight. Next morning I hook it up and go to start. Just a click. A few taps on the starter with a baton and several cycles of the key and it starts cranking incredibly slowly again, no change from earlier. In addition, I can smell something like burning rubber or plastic after attempting to start. That's not smoke in the engine bay in the video though, just my breath.
- New battery
- Alternator is charging
- Battery terminals are clean and tight
- Ground connections are tight and intact
- Note the unusual whine
Link
Any ideas? Does my starter need new parts or a replacement, or could the problem be somewhere else?
Starter motor busted - Please help!
- VectraGoVroom
Re: Starter motor busted - Please help!
It does sound like the starter motor is struggling really badly, could just have burned itself out. If you're going to remove it, you may as well get a replacement.
It would have helped if you'd kept the camera over your dash lights for the entire crank but you got there eventually
Dash lights dimming: I'd say worn bushings, brushes or commutator - if you're really unlucky, all of the above.
If this is the case your ignition system will be ramming current into the starter to compensate and this will explain the 'burning plastic' smell - you're frying the harness.
Do the battery cables (positive and negative) get warm after the crank?
Personally, I'd rather you didn't try this again as you risk permanent damage to the wiring harness which is a significantly bigger problem than sourcing a new starter - which is what it sounds like.
Verdict: reasonably safe bet that it's the starter
- VectraGoVroom
Problem solved. Amazing how much quieter the new motor is.
