I fitted the Omega estate wiper stalk and Omega intermittent relay today and all the wiper work on the 2 settings barring the back wiper.When i put the wipers on the 1st setting the wipers work every 2 secs,but when i turn the wheel nothing happen.Could the relay be faulty,or could it be the Omega stalk.Is there a procedure i should do (turn ignition on and off,or reset ECU by disconnecting battery) so the wipers work with the wheel.
Should the Omega estate wiper stalk work on a Kreg Cavalier TD hatchback?... I had the same setup on my Mreg Cavalier TD hatchback and it worked fine.
Omega Wiper Stalk Not Working
Re: Omega Wiper Stalk Not Working
Sorted,wired it up wrong.
Im getting clumsy in my old age,but i did do the wiper stalk at night,lol.
Sorry guys n gals for bothering you.
Glad you got to the bottom of it!
