Rear widow de mist not working
My rear window appears to given up de misting, before I start investigating is it generally the rear window or is it sometimes an easy fix?
Re: Rear widow de mist not working
Start by checking obvious things (fuse, connections, switch etc). Unless you've hit it or scraped something very heavily down the glass, you're not likely to have broken the element.
Does yours have electric door mirrors? Turning on the rear screen demister should warm them, or at least put a light on on the mirror adjuster. That'd give you an idea that the circuit is working at least.
1990 Astra 2.0 8v GTE Cabrio
2018 Jaguar XE 180 R-Sport
If it is a heater element issue, it will be the connections to the element... not the element itself.
Possibly snapped off connection.
Otherwise usually fuse or relay issue.
The relay is buried behind the fuse box, on the relay frame.
Hi mate yea the heated mirrors work etc so hopefully it's a connection to the rear window?
Is your car a hatch or saloon? If a hatch it could be the cables broken where it bends & goes into the hatch itself.
