Noise lasts for 3 seconds.
Alternator fan belt very slightly too slack.
Background: An alternator in good condition can provide well over 200 Amps of charging current to the lead acid starter battery that has been partially discharged by use of the starter motor. This represents over 3 horse power of output that the alternator drive belt has to transmit and it tends to slip producing the noise.
Caution: over tight drive belts will cause failure of alternator bearings.
A happy compromise is a scream that lasts for half a second.
The alternator can replace the drain of a typical quick start within 5 minutes at a fast tick-over. Revving the engine is unnecessary and will lead to premature bearing wear as oil takes some time to fully float shafts. Ample current should be available for rear-screen heaters etc. at 1300 rpm. Avoid using lights for the first 5 seconds after an engine start. Alternator output voltage can be as high as 19V and this blows bulbs.
Scream under bonnet imediately after starting.
Return to “Faults and Fixes: ICE and Electrical”
Jump to
- THE OFFICE
- ↳ Announcements
- ↳ Forum Support
- ↳ The Suggestion Box
- ↳ Useful Links
- ↳ Meet the Team
- THE SHOWROOM
- ↳ Projects, Restorations and Runabouts
- ↳ Your non-Cavalier Projects
- THE WORKSHOP
- ↳ Faults and Fixes: Mk3 Cavalier Workshop Guides
- ↳ Faults and Fixes: Mechanical
- ↳ Faults and Fixes: Fuel Systems and Exhausts
- ↳ Faults and Fixes: Brakes and Suspension
- ↳ Faults and Fixes: Bodywork and Interior
- ↳ Faults and Fixes: ICE and Electrical
- ↳ Faults and Fixes: General Maintenance and Servicing
- ↳ Faults and Fixes: Other
- THE BODYSHOP
- ↳ Wheels and Tyres
- ↳ Detailing Discussion
- THE ARCHIVE
- ↳ The Car's the Star
- ↳ Mk3 Cavalier Promotional Videos
- ↳ Model-specific Tech Info
- ↳ Contemporary reviews, articles and information
- ↳ Mk3 Cavaliers in Motorsport
- ↳ Mk3 Cavalier models
- THE LOUNGE
- ↳ Introduce yourself
- ↳ General Chat
- ↳ Spotted
- ↳ Events, Meets, Gatherings and Parties
- ↳ Gaming, Gadgets and Computing
- ↳ The Sports Locker
- ↳ TV and Movies
- ↳ The Discotheque
- ↳ The Truth About Cats and Dogs
- ↳ The Cake Shop
- ↳ Photography and Camera Equipment
- THE FORECOURT
