Removed my clocks tonight to wire up a speed sensor and my speedo stopped working. Checked cable and thats turning whilst driving. Iv checked to make sure its connected. Are the clocks known to fail that easy?
Just wondering if theres something else i can do before finding some more clocks
Speedo not working
Re: Speedo not working
I am assuming standard mechanical cable.
Only two things come to mind.
1 - cable is snapped somewhere along it's length.
So assuming that turning one end of the cable causes the other end to do likewise, then that rules out the cable.
2 - cable not quite plugged in / engaged at either end.
But you state that the cable is indeed fully located in the back of the speedo head.
I have never had a mechanical speedo fail on any of my cars. It does sound odd that yours has failed after doing some work on the cable.
I would just recheck that the cable is properly engaged.
I didn't think they were particularly weak or easy to break.
I was going to ask this I'm my WIP thread but as it's come up; I'm having a similar problem with my LS.
Occasionally, normally when it hasn't been driven in a while, the speedo won't work at all for the first mile or so of driving. It will just sit at the bottom of the dial until it suddenly springs into life, after which it works as normal for the remainder of the journey.
I haven't checked anything or fiddled with anything yet. It just developed on it's own accord.
I used to have a problem with the rev counter whereby it would give inaccurate readings and jump around the dial randomly. Funnily enough this fixed itself while in storage and it reads perfectly now.
I've had this in the past where the cable has snapped in such away that it turns, but doesn't turn when it has the clocks connected (too much load), or is kinked in such a way that it can't turn properly.
My advisee would be to disconnect from the gearbox end and see if turning the cable manually moves the speedo.
Envoy is correct. It turned whilst driving but i removed it completely and found it broken. Good job i have a new one
Glad I could offer some advise on that
