C18NZ - Alternator wiring
jgwilliamson
Post by jgwilliamson »
Hi,
Can anyone confirm the wiring for the alternator on my C18NZ? I disconnected the old one some time ago and did take a photo (See link) so I know where the big red cable goes, but does the blue and white one connect to the other terminal on the alternator in the photo below?
(Confusingly there is a second blue and white wire coming from the same loom, but I labelled it going to a connector on the oil filter mounting. Wish I'd done the same with the other one...doh!)
https://drive.google.com/file/d/1HWCiwD ... sp=sharing
John
Re: C18NZ - Alternator wiring
The blue / white goes to the alternator.
It controls the charge warning light on the dash.
The other blue wire should have a green stripe on it.
That is for the oil pressure warning light.
If it is a plain blue wire, then the sensor nearest to match would be the coolant temperature sensor on the front of the thermostat housing.
jgwilliamson
Cheers Robsey :)
