Hi all, I have an electric sun roof out of a Cav CDX that I want to fit in my SRi. My question is the thick black wire that goes down the side of the front window, is this the power wire and can it be wired in any where else save trying to feed it down the A post. Also has anyone got any pics of one being installed?
Thanks Tez
Fitting electric sunroof
Re: Fitting electric sunroof
viewtopic.php?f=45&t=823
The answers are here! For the omega roof anway, but should imagine the wiring is pretty much the same.
- Greig Sri
You get the new main power for the motor from a conection in the main wiring loom. You will find the conector behind the lower side kick panel on the pas side of the car. Put a fuse in the fuse box for the sunroof to find the correct conection in the multi plug on the loom. By testing for power you can find it, rember the igination needs to be turned on to feed power to the sunroof. Then run your new black wire you have up the A piller to the sunroof.
Nice one, I'll have a go tomorrow weather permitting.
