Hi Folks,
Hope that one and all are enjoying the festivities
Cav 3 dt is problem.
I am great with chops/trikes but haynes has me stumped.
Seem to lay out diagram for all models on the same loom. Is that right?
Want a diagram for my wifes M reg envoy. Any pointers?
Problem started with idiot light for seat belt staying on. Took bulb out noe abs comes on/goes off at will .
Battery seems to be struggling,need to drop test it I guess.
Any common probs on these?
ta
drew
Hatred of haynes wiring diagram
Re: Hatred of haynes wiring diagram
there isnt a bulb for seatbelt cavs dont have that. Was it not the airbag light?
Id check that the plug is on the back of the clocks as the abs is pretty much a standalone system
viewtopic.php?f=17&t=2604
check here for a wiring diagram, basically one side is earth and the other is live, all the colourcodes are in german but there is a list of translations at the beginning of the section
- trikerdrew
Cheers for that.
I'll check the plug on the back before I start pulling stuff off.
Would indeed appear to be the airbag light
ta
drew
ta
drew
if the steering wheels been off with the battery connected that would normally be the source of your problems too.
- trikerdrew
This car is run on magic!
Just swopped alt and batt . Gone to swop relay and there isn't one. The alt has four wires though-weird
drew
drew
On a TD, the relay is up in the back of the fuse box, green one I think.
