Rev Counter not working?
- GsiCav2000
rev counter has stopped working since new engine has been put in!
Any Idea's ... thanks
- Greig Sri
Re: Rev Counter not working?
Wiring fault, have you checked the wire for it. I think it a green wire.
- GsiCav2000
where doe's the wire go to?
- GsiCav2000
where about doe's it connect to on the coil?? its a different coil to what was on my last engine.
it's looks like it connects into something like a plug! its its a black plug with a green rubber seal around it! should it fit onto my coil handy enough?
Thanks
Thanks
Green wire needs to be plugged in, might be a plug under the dash you haven't plugged in, or the wire isn't there.
- GsiCav2000
the green wire is just hanging out off the loom beside the coil but don't know where it goes.
the coil has a green and black wire to the positive and a black earth wire to the frame! there's also that other green wire hanging with the loom???
Pictures please
- GsiCav2000
what should i do just cut off the plug end off the green wire and wire it to the negative black wire on the coil ?
- GsiCav2000
i tried it to the negative but still not working!
