was wondering?
will the HT leads be the same from a 1.6 8v to 2.0 8v?
or would it do anything if i put more performance ones onto it?
any idea's on what mite fit?
HT leads power
Re: HT leads power
If anything the conections may be different, but at en of the day the cable is the same. Just differnt thickness depending on what you buy, as rule of thumb they say if the leads are more than 5 years old then replace. But if you want to know if they'll fit, lok on internet auto shops and see if the serial number for the leads used on one engine are the same as used for another. Must the time things like that are across the range, For example the oil filters and spark plugs are the same on all cavaliers etc. Or if you're passing a halfords look ate the cables there, They'l have all cars the work on printed on the side of the box.
