oil and volt gauges
oil and volt gauges
does any body know if the oil and volt gauges from a calibra can be wired in to a sri and if so how to do it, many thanks.
Re: oil and volt gauges
Yes it can be wired to any Cavalier, as long as you put in the necessary wires.
You will need
1) an Oil Pressure sender (not just a switch), from a Calibra, Frontera etc
2) Wire from 2nd terminal of the sender to the oil gauge
3) Ignition live for battery gauge (black)
4) Ground wire (brown)
5) Illumnation wire (grey/green or grey/black).
Do not wire this up wrong, as the oil gauge will be blown of the scale and damaged beyond repair.
I'm sure there is a How 2 for this.
Hope that helps
You will need
Hope that helps
