Idle stepper motor (Spi version of the ICV)
Does anyone know how the Idle Stepper Motor works?
Re: Idle stepper motor (Spi version of the ICV)
I found this on another forum, it sort of explains what the ICV or idle stepper motor does.
The purpose of the idle control valve is to provide air to the intake of the engine when the throttle plenum (butterfly) is shut so ONLY when the engine is idling. To cut down on emissions the ECU checks the lambda sensor in the exhaust for the mixture and measures out the minimum possible amount of fuel to inject and the minimum possible amount of air to allow to bypass the intake plenum through this valve to get the perfect mixture on idle, giving you a nice smooth idle and no rich smells.
The problem with this is that the idle control valve can occasionally get little bits of oil blown back through it from the engine breathers causing it to stick slightly. When this happens it can give you poor idling, cutting out, jerkiness on coasting, jerkiness on acceleration, poor acceleration etc.
Yup, that sounds like the ticket for me.
I believe it is possible to clean out the ICV, possibly with carb cleaner (I presume).
Although, it shouldn't take long to wip out yours and fit the replacement in it's place.
Quicker to replace than clean, I would have thought.
replacement is pretty oily too, but gives me a chance to see whats its like withthe new one. T20 screws hold it in place under the injector.
sounds like the good old "clogged breather system" scenario to me.
The joys, Going to have to do some stripping down on the engine.
Will this be another world famous How 2 ?
Probably, depends how awake I am when I do it
or if you can fit it into your very busy schedule!!
Replaced the ISM today, initial turn of the key and I thought "bugger, it's not worked.. as it ran barely at 350-400rpm and was hunting badly with the EML light on, gave it a little blip and it soon sorted itself out and idles at around 600-650rpm now.
I think that is still a little low, but I could be wrong.
I thought it was more towards 750 to 850 on an auto.
Anyway, as long as it runs smoother, then the jobs a good un !!
Good news.
Good news.
It is low should be 800-880 but its smoother and not as erratic so alls good.
Will probably get closer to the correct idle rpm after the ECU learns the new valve's parameters.
Yeah, it started hunting between 600 and 1000 rpm today, but it didn't sound like it did, so it's probably learning.
forgot to say, assuming you disconnected the battery to reset the ECU to allow it to re-learn everything.
Toyed with doing that overnight.
I read somewhere, that whenever you change anything, especially sensors, or sensor controlled items, then you should disconnect the battery for about thirty minutes or so.Robsey wrote:
Then reconnect up, and take your cav for a brisk blast down the motorway.
Don't know how much truth is in the notion that the car should then run more economical and smoother, when you drive at a less riotous rate!!
Might have a run out for a coffee and disconnect the battery then reconnect it when I've finished
Great ! - Mines a Latte
Let me know when you hit Weatherby then.Robsey wrote:Great ! - Mines a Latte
Has this settled now then?
If not fully sorted,
Suppose you could just clean it with carb spray, and then re-lube with 3 in 1 oil, just to be on the safe side.
You could do this on your original one, swap them back around, and see what, if any difference there is.
If it is sorted, then you could always clean the old one and keep it as a spare.
Half my trouble is I never throw anything away I have rattley backboxes kicking about just incaseRobsey wrote:Has this settled now then?
I will probably clean the old one at some point. Need to knock the battery off at some point and let it "reset" itself.
There you go, convert to a V6 or V8 short block, and use two back boxes.
One for each bank of cylinders.
Hmmm but then you find you have barely any space for the working spares.
Robsey wrote:There you go, convert to a V6 or V8 short block, and use two back boxes.
Aye, need to have a really big tidy out at some point.
