FUSES - No., Function and Rating
I don't think this is listed in the reference section, so here is the layout of the fuses within the fusebox.
(Based on a late 1994 Owner's Handbook).
01 - 10A - parking and tail lights - left
02 - 20A - heated front seats - cigar lighter - instrument cluster dials and tell tales.
03 - 10A - main beam left
04 - 30A - heater fan (Not with Air Con).
05 - 10A - dipped beam left
06 - 30A - windscreen wiper and horn
07 - 15A - indicators and brake lights, ABS
08 - 15A - interior lighting, hazards, clock, radio, DID, fuel computer
09 - 10A - instrument illumination and number plate
10 - 30A - sun roof
11 - 20A - fuel pump and fuel injection
12 - 10A - electric mirrors, electric windows and central locking
13 - 20A - front fog lights
14 - 10A - ABS and Autobox
15 - 30A - heated rear window
16 - 10A - Auto box
17 - 20A - central door locking
18 - 10A - daytime running lights - sweden only
19 - 10A - 4 x 4
20 - 10A - Radio
21 - 10A - parking and tail lights - right
22 - 10A - carb pre-heating, reverse lights, on board computer
23 - 10A - main beam right and tell-tale
24 - 30A - cooling fan
25 - 10A - dipped beam - right, headlamp range adjustment
26 - 30A - electric rear windows
27 - 10A - fog tail lights
28 - 20A - Caravan split charge - constant 12V
29 - 10A - Headlamp washers
30 - 30A - front electric windows
Fuses are in 3 rows
1 ---------------> 10
11 -------------->20
21---------------->30
Hope this Helps
10 - 30A - sun roof
16 - 10A - Auto box
19 - 10A - 4 x 4
20 - 10A - Radio
Fuses are in 3 rows
Hope this Helps
Re: FUSES - No., Function and Rating
Good point actually Robsey, I don't think I've seen this listed anywhere else on the site. So good job there, nice and simply laid out.
Andrei.
Andrei.
Well presented.
It has only taken me 9 years, since the original Dash Panel Fuse Box was posted up.
But hey ho, here we go.
I have had to split this into model year groups as Vauxhall / Opel moved things about.
Engine Compartment Relay / Fuse Box
Listings are Fuse Number = Position in the Fuse Box = Function (Comments)
1989 to 1991
F32 = Pos 3a = Mixture Pre-Heating (1989 to 90)
F33 = Pos 3b = Voltage Supply (1989 to 90)
F34 = Pos 5 = Auxiliary Fan
F36 = Pos 8a = Fuel Preheating (1989)
F36 = Pos 4a = Fuel Preheating (1990)
F36 = Pos 12a = Fuel Preheating (1991)
F38 = Pos 4, 8 or 12 = Horn Anti Theft System
F39 = Pos 5a / 6a = Head Lamp Washer (1990)
F39 = Pos 8 = Head Lamp Washer (1991)
F40 = Pos 9a = Radiator Fan (1990 & 1991)
F41 = Pos 13 = Glow Plug Glow Period
F42 = Pos 13 = Radiator Fan 2nd Speed (1991)
1992
F34 = Pos 1a = Auxiliary Fan (17DT)
F34 = Pos 13 = Auxiliary Fan (C20LET)
F34 = Pos 10a = Auxiliary Fan (AC or 17DT)
F38 = Pos 4 = Horn Anti Theft System
F40 = Pos 5a = Radiator Fan
F42 = Pos 10b = Radiator Fan 2nd Speed (17DT)
F42 = Pos 13b = Radiator Fan 2nd Speed (AC)
F42 = Pos 9a = Radiator Fan 2nd Speed (Not AC)
F42 = Pos 6b = Radiator Fan 2nd Speed (17DT)
1993 to 1994
F34 = Pos 9b / 13a = Auxiliary Fan (Not AC)
F34 = Pos 10a = Auxiliary Fan (AC)
F34 = Pos 6a = Auxiliary Fan (17DT)
F36 = Pos 12a = Fuel Preheating (1993)
F42 = Pos 9a = Radiator Fan 2nd Speed (Not AC 1993)
F42 = Pos 13b = Radiator Fan 2nd Speed (AC 1993)
F46 = Pos 3a = Pollen Filter Heater Fan (1994)
F47 = Pos 13a = Air-conditioning
F48 = Pos 10a = Traction Control (Not AC)
F48 = Pos 10b = Traction Control (AC)
F49 = Pos 11a = Secondary Air Pump (1994)
1995
F34 = Pos 9a,10a or 14a = Auxiliary Fan (Not 17DT)
F42 = Pos 14a, 14b = Radiator Fan 2nd Speed (AC)
F47 = Pos 14a = Air-conditioning
F49 = Pos 11a = Secondary Air Pump (Not AC)
F49 = Pos 8a = Secondary Air Pump (AC)
As for the relays... please bare with me.
There are loads and loads in the relay frame behind the dash fuse box, and in the engine bay fuse box.
I think it goes up to K108!!
1989 to 1991
1992
1993 to 1994
1995
RELAYS IN THE DASH FUSE BOX
There are 6 relays in the fuse box.
1 to 4 are from Top Left to Top Right,
5 is below 4 and 6 is below 5.
My 1994 Fuse Box and Relays shown.
In order -
1 - Grey warbling lights on warning sounder.
2 - Black flasher unit with extra pin for tow-bar tell-tale on dash.
3 - Yellow Omega-B variable intermittent wiper delay relay.
4 - Rear Fog bypass wire.
5 - Front Fog Relay
6 - Fanfare Relay.
Here are the "Proper" listings.
Model Years 1989 to 1990
1 = H19 - Headlamps on Warning Buzzer
2 = K10 - Turn Signal Flasher Relay
3 = K8 - Wiper Interval Relay
4 = K89 - Rear Fog Lamp Relay or Bypass Wire
5 = K5 - Front Fog Lamp Relay
6 = K1 - Heated Rear Screen or K63 Dual Horn / Fanfare Relay
Model Years 1991 to 1995
2 = K8 - Turn Signal Flasher Relay
3 = K5 - Wiper Interval Relay
5 = K1 - Front Fog Lamp Relay
6 = K10 - Horn Relay or K63 Dual Horn / Fanfare Relay
In order -
5 - Front Fog Relay
6 - Fanfare Relay.
The Official Fuse Listing. (In full Detail)
Fuse Number - Fuse Rating.
Circuits Protected.
Fuse 1 - 10 amps
Left tail lamp
Right tail lamp
Trailer socket, Ter. 58 L
Control unit, system monitoring
Headlamp range control, left MY '90
Fuse 2 - 20 amps
Instrument assembly
Control unit, ride control up to MY '92
Control unit, four wheel drive
Seat heating
Fuse 3 - 10 amps
Cigarette lighter
Lamp, cigarette lighter
Control unit, catalytic converter temperature
Glove compartment lamp
Time relay, heated rear screen and mirror as of MY '92
Control unit, AC as of MY '92 and/or radiator fan
Control unit for radiator fan C 25 XE, 17 DT engines as of MY '93
Control unit for radiator fan X 20 XEV engines as of MY '94
Instruments, auxiliary as of MY '95
Motor, antenna
Fuse 4 - 30 amps
AC fan or heating fan
Switch, AC fan
Fuse 5 - 10 amps
Headlamp range control, left MY '89 and MY '90½ up to MY '94
Low beam, left
System monitoring
Bulb control sensor MY '90 up to MY '92
Fuse 6 - 30 amps
Windscreen/rear screen washer pump
Motor, rear screen wiper
Motor, windscreen wiper
Horn up to MY '92
Time relay, washer pump, headlamps
Fuse 7 - 15 amps
Brake lamp, right
Brake lamp, left
Socket, trailer
System monitoring
Switch, hazard warning lamps
Control unit, ABS
Control unit, automatic transmission
Fuse 8 - 15 amps
Interior lamp, switch-off delay
Board computer
Clock
System monitoring
Control unit, four wheel drive MY '89
Radio as of MY '92
Automatic antenna as of MY '90
Interior lamps, rear MY '91
Relay, radiator fan K26, as of MY '93
Lamp, luggage compartment
Reading lamps, rear, as of MY '92
Lamps, vanity mirror, as of MY '92
Relay, radiator fan K27, as of MY '93
Dual-Info-Display, as of MY '94
Fuse 9 - 10 amps
License plate lamp
Lamp, engine compartment up to MY '94
Control unit, low beam driving lamps up to MY '92
Illumination, switch, front fog lamps
Relay, front fog lamps
Warning buzzer, headlamp switched-on control
Illumination, instrument assembly
Solenoid valve, headlamp washer
Washer, headlamps
Lamp, clock up to MY '94
Illumination, switch, ride control MY '89
Illumination, AT selector lever
Illumination, AC switch
Illumination, heated rear screen switch
Illumination, switch, rear fog lamp
Illumination, switch, seat heating, left
Illumination, switch, seat heating, right
Illumination, switch, headlamp range control
Radio
Relay, daytime driving lamps as of MY '92
Illumination, switch, recirculating air as of MY '92
Illumination, switch, traction control as of MY '93
Fuse 10 - 30 amps
Sun roof, electric
Circuits Protected.
Fuse 1 - 10 amps
Left tail lamp
Right tail lamp
Fuse 2 - 20 amps
Instrument assembly
Seat heating
Fuse 3 - 10 amps
Cigarette lighter
Motor, antenna
Fuse 4 - 30 amps
Switch, AC fan
Fuse 5 - 10 amps
Low beam, left
System monitoring
Fuse 6 - 30 amps
Horn up to MY '92
Fuse 7 - 15 amps
Brake lamp, right
Brake lamp, left
Socket, trailer
System monitoring
Control unit, ABS
Fuse 8 - 15 amps
Board computer
Clock
System monitoring
Radio as of MY '92
Fuse 9 - 10 amps
License plate lamp
Washer, headlamps
Radio
Fuse 10 - 30 amps
Sun roof, electric
Fuse 11 - 20 amps
Fuel pump
Control unit, anti-theft warning system (RHD only) as of MY '93
Control unit, anti-theft warning system (Germany only) as of MY '94
Immobiliser (radio controlled) as of MY '95
Fuse 12 - 10 amps
Control unit, central locking
Control unit, automatic window winders
Adjustment and heating, outside mirror
Fuse 13 - 20 amps
Front fog lamps,left
Front fog lamps, right
Telltale in switch, front fog lamps
Relay, rear fog lamp as of MY '92
Fuse 14 - 10 amps
Illumination, switch, drive-off assistance
Control unit, AT
Relay, surge arrestor up to MY '92
Control unit, anti-lock brake system as of MY '92
Fuse 15 - 30 amps
Heated rear screen
Heated outside mirror
Telltale, heated rear screen as of MY '92
Control unit, anti-theft warning system as of MY '93
Fuse 16 - 10 amps
Control unit, AT
Fuse 17 - 20 amps
Fuse 18 - 10 amps
Fuse 19 - 10 amps
Solenoid valve, four wheel drive
Fuse 20 - 10 amps
Radio up to MY '92
Fanfare as of MY '92
Fuel pump
Fuse 12 - 10 amps
Fuse 13 - 20 amps
Fuse 14 - 10 amps
Control unit, AT
Fuse 15 - 30 amps
Heated rear screen
Fuse 16 - 10 amps
Control unit, AT
Fuse 17 - 20 amps
Fuse 18 - 10 amps
Fuse 19 - 10 amps
Fuse 20 - 10 amps
Radio up to MY '92
Fuse 21 - 10 amps
Parking lamp, left
Parking lamp, right
Socket, trailer
License plate lamp with daytime driving lamps as of MY '90
Headlamp range control, right MY '90 up to MY '91½
Fuse 22 - 10 amps
Warning buzzer, headlamp switch-on control
Reversing lamps, left
Reversing lamps, right
Illumination, switch, lamps
Solenoid valve, cold start acceleration
Relay, filter heating
Switch, AT
Switch, ride control MY '89
Control unit, ride control MY '89
Board computer
Carburettor preheating up to MY '93
Start automatic up to MY '93
Control unit, glow period MY '90 up to MY '93
Relay, sheathed glow plugs MY '90 up to MY '93
Relay, series resistor MY '90 up to MY '93
Control unit, system monitoring as of MY '90
Warning buzzer, safety control as of MY '92
Control unit, catalytic converter temperature as of MY '92
Dual-Info-Display (DID) as of MY '93
Solenoid valve, coolant (Japan) as of MY '94
Fuse 23 - 10 amps
High beam, right
Telltale, high beam
Fuse 24 - 30 amps
Motor, radiator fan
Series resistor, radiator fan
Fuse 25 - 10 amps
Low beam, right
Headlamp range control MY '89
Switch, headlamp range control MY '90
System monitoring
Motor, headlamp range control, right MY '90½ up to MY '94
Motor, headlamp range control, left and right as of MY '94
Fuse 26 - 30 amps
Electronic window winders, rear
Fuse 27 - 15 amps
Rear fog lamp, left
Rear fog lamp, right
Fuse 28 - 20 amps
Socket, trailer
Fuse 29 - 10 amps
Washer, headlamps
Interior lamp up to MY '92
Washer, windscreen/rear screen
Washer nozzle, heated as of MY '91
Fuse 30 - 30 amps
Electronic window winders, front
Parking lamp, left
Parking lamp, right
Socket, trailer
Fuse 22 - 10 amps
Switch, AT
Board computer
Fuse 23 - 10 amps
High beam, right
Telltale, high beam
Fuse 24 - 30 amps
Motor, radiator fan
Fuse 25 - 10 amps
Low beam, right
System monitoring
Fuse 26 - 30 amps
Fuse 27 - 15 amps
Rear fog lamp, left
Fuse 28 - 20 amps
Socket, trailer
Fuse 29 - 10 amps
Washer, headlamps
Fuse 30 - 30 amps
1989 Model Year
Additional Fuses, Relays and Modules - And their locations.
Engine Bay Fuses.
F32 - Mixture preheating - Engine compartment relay frame - Pos 3a
F33 - Voltage supply - Engine compartment relay frame - Pos 3b
F34 - Auxiliary fan - Engine compartment relay frame - Pos 5
F36 - Fuel preheating - Engine compartment relay frame - Pos 8a
F38 - Horn, anti-theft warning system - Relay frame behind fuse box - Pos 4/8/12
Buzzer Relay
H19 - Warning buzzer headlamps switch-on control - Fuse box - Pos 1
Relays, Control Units and Modules.
K1 - Heated rear screen - Fuse box - Pos 6
K3 - Anti-theft warning system Starter - Relay frame behind fuse box - Pos 8/12/22
K5 - Front fog lamps - Fuse box - Pos 5
K6 - Air conditioning - Relay frame behind fuse box - Pos 5
K7 - AC fan, 4th speed - Relay frame behind fuse box - Pos 6
K8 - Windscreen wiper interval - Fuse box - Pos 3
K10 - Turn signal unit - Fuse box - Pos 2
K25 - Glow period - Engine compartment relay frame - Pos 11
K30 - Rear screen wiper interval - Relay frame behind fuse box - Pos 1
K35 - Heated outside mirror - Front lower left, rear quarter panel - Pos B1
K37 - Central locking - Behind right foot-well paneling - Pos 4
K45 - Mixture preheating - Engine compartment relay frame - Pos 7
K47 - Voltage surge arrestor (ABS) - Engine compartment relay frame - Pos 10
K50 - ABS control unit - Beside driver's seat - Pos A1
K51 - Radiator fan 2nd speed - Engine compartment relay frame - Pos 1
K54 - Electronic carburettor - Behind right foot-well paneling - Pos 1
K55 - Voltage supply - Engine compartment relay frame - Pos 11
K57 - Central fuel injection - Behind right foot-well paneling - Pos 1
K59 - Daytime driving lamps - Relay frame behind fuse box - Pos 13
K61 - Motronic - Relay frame behind right foot-well paneling - Pos 1
K62 - Dipped driving lamps - Relay frame behind fuse box - Pos 13
K63 - Fanfare - Relay frame behind fuse box - Pos 2
K63 - Fanfare - Fuse box - Pos 6
K64 - AC fan, 1st speed - Relay frame behind fuse box - Pos 7/11
K67 - Radiator fan, 1st speed Auxiliary fan, 17 DT - Engine compartment relay frame - Pos 2
K68 - Fuel injection system - Engine compartment relay frame - Pos 11
K69 - Motronic - Behind right foot-well paneling - Pos 1
K73 - High beam - Relay frame behind fuse box - Pos 4
K76 - Glow period - Behind right foot-well paneling - Pos 3
K77 - Sheathed glow plugs - Behind right foot-well paneling - Pos 1
K78 - Series resistor - Behind right foot-well paneling - Pos 2
K79 - Charge control - Behind right foot-well paneling - Pos 5
K80 - Fuel preheating - Engine compartment relay frame - Pos 7
K82 - Engine speed, cold start acceleration - Engine compartment relay frame - Pos 3
K83 - 4 wheel drive - Under instrument panel, left - Pos C1
K84 - EI Plus - Engine compartment bulkhead, centre - Pos E1
K85 - Automatic transmission - Behind glove compartment - Pos D1
K86 - Check Control - Above glove compartment - Pos E1
K87 - Auxiliary fan - Engine compartment relay frame - Pos 6
K88 - Catalytic converter temperature - Relay frame behind fuse box - Pos 13
K89 - Rear fog lamp - Fuse box - Pos 4
K90 - AC compressor (AT) - Relay frame behind fuse box - Pos 8
K95 - Heated outside mirror - Relay frame behind fuse box - Pos 2
K97 - Headlamp washer - Engine compartment relay frame with ABS - Pos 9
K97 - Headlamp washer - Engine compartment relay frame without ABS - Pos 10
Sensors.
P39 - Bulb control sensor, trailer hitch - Relay frame behind fuse box - Pos 3
Engine Bay Fuses.
Buzzer Relay
Sensors.
1990 Model Year
Engine Bay / Relay Frame Fuses.
F36 - Fuel preheating - Engine compartment relay frame - Pos 4a
F39 - Headlamp washer - Relay frame behind fuse box - Pos 5a/6a
F40 - Radiator fan - Engine compartment relay frame - Pos 9a
F41 - Glow period - Engine compartment relay frame - Pos 13
Buzzer Relay
K9 - Headlamp washer - Engine compartment relay frame - Pos 1/2
K25 - Glow period - Engine compartment relay frame - Pos 12
K37 - Central locking - Behind right foot-well panelling - Pos 4
K47 - Voltage surge arrestor (ABS) - Engine compartment relay frame - Pos 2
K51 - Radiator fan 2nd speed - Engine compartment relay frame - Pos 9
K51 - Radiator fan 2nd speed - Engine compartment relay frame for 17 DT engine - Pos 10
K54 - Electronic carburettor - Behind right foot-well panelling - Pos 1
K57 - Central fuel injection - Behind right foot-well panelling - Pos 1
K61 - Motronic - Relay frame behind right foot-well panelling - Pos 1
K67 - Radiator fan, 1st speed Auxiliary fan, 17 DT - Engine compartment relay frame - Pos 10
K69 - Motronic - Behind right foot-well panelling - Pos 1
K76 - Glow period - Behind right foot-well panelling - Pos 3
K77 - Sheathed glow plugs - Behind right foot-well panelling - Pos 1
K78 - Series resistor - Behind right foot-well panelling - Pos 2
K79 - Charge control - Behind right foot-well panelling - Pos 5
K80 - Fuel preheating - Engine compartment relay frame - Pos 3
K82 - Engine speed, cold start acceleration - Engine compartment relay frame - Pos 8
K97 - Headlamp washer - Engine compartment relay frame with ABS - Pos 1
K97 - Headlamp washer - Engine compartment relay frame without ABS - Pos 2
Sensor
Buzzer Relay
Sensor
1991 Model Year
Engine Bay and Relay Frame Fuses
F36 - Fuel preheating - Engine compartment relay frame - Pos 12a
F39 - Headlamp washer - Relay frame behind fuse box - Pos 8
F42 - Radiator fan (2nd speed) - Engine compartment relay frame - Pos 13
Buzzer Relay
K6 - Air conditioning - Relay frame behind fuse box - Pos 6
K7 - AC fan, 4th speed - Relay frame behind fuse box - Pos 10
K9 - Headlamp washer - Engine compartment relay frame - Pos 3
K25 - Glow period - Engine compartment relay frame - Pos 8
K47 - Voltage surge arrestor (ABS) - Engine compartment relay frame - Pos 1/2
K58 - Fuel pump - Behind right foot-well panelling - Pos 3
K68 - Fuel injection system - Engine compartment relay frame - Pos 3
K69 - Simtec - Behind right foot-well panelling - Pos 1
K80 - Fuel preheating - Engine compartment relay frame - Pos 11
K82 - Engine speed, cold start acceleration - Engine compartment relay frame - Pos 4
K87 - Auxiliary fan - Engine compartment relay frame - Pos 5/6
K90 - AC compressor (AT) - Relay frame behind fuse box - Pos 3/7
K97 - Headlamp washer - Engine compartment relay frame - Pos 3
K102 - Parking lockout - Engine compartment relay frame - Pos 4
K103 - Radiator fan - Engine compartment relay frame - Pos 11
Sensor
P39 - Bulb control sensor, trailer hitch - Relay frame behind fuse box - Pos 1
Buzzer Relay
Sensor
1992 Model Year
F34 - Auxiliary fan - Engine compartment relay frame for 17 DT engine - Pos 1a
F34 - Auxiliary fan - Engine compartment relay frame for C 20 LET engine - Pos 13
F34 - Auxiliary fan - Engine compartment relay frame for AC or 17 DT engine - Pos 10a
F40 - Radiator fan - Engine compartment relay frame - Pos 5a
F42 - Radiator fan (2nd speed) - Engine compartment relay frame for 17 DT engine - Pos 10b
F42 - Radiator fan (2nd speed) - Engine compartment relay frame with AC - Pos 13b
F42 - Radiator fan (2nd speed) - Engine compartment relay frame without AC - Pos 9a
F42 - Radiator fan (2nd speed) - Engine compartment relay frame for 17 DT engine – Pos 6b
F47 - Air conditioning - Engine compartment relay frame - Pos 13a
Buzzer Relay
K34 - Radiator fan, run-on - Engine compartment relay frame without AC - Pos 4
K34 - Radiator fan, run-on - Engine compartment relay frame with AC - Pos 5
K35 - Heated outside mirror - Front lower left, rear quarter panel - Pos 2
K51 - Radiator fan 2nd speed - Engine compartment relay frame for 17 DT engine - Pos 5, 6
K52 - Auxiliary fan - Engine compartment relay frame - Pos 1
K67 - Radiator fan, 1st speed Auxiliary fan, 17 DT - Engine compartment relay frame - Pos 2, 6
K87 - Auxiliary fan - Engine compartment relay frame - Pos 2
Sensor
U4.8 - ABS control unit - Engine compartment - Pos C1
Buzzer Relay
Sensor
1993 Model Year
F34 - Auxiliary fan - Engine compartment relay frame without - Pos 9b/13a
F34 - Auxiliary fan - Engine compartment relay frame with AC - Pos 10a
F34 - Auxiliary fan - Engine compartment relay frame for 17 DT engine - Pos 6a
F48 - Traction control - Engine compartment relay frame without AC - Pos 10a
F48 - Traction control - Engine compartment relay frame with AC - Pos 10b
Buzzer Relay
K22 - Coolant run-on pump - Engine compartment relay frame without AC - Pos 5
K22 - Coolant run-on pump - Engine compartment relay frame with AC - Pos 9
K26 - Radiator fan - Engine compartment relay frame - Pos 5
K27 - Radiator fan - Engine compartment relay frame - Pos 6
K51 - Radiator fan 2nd speed - Engine compartment relay frame for 17 DT engine - Pos 5, 10
K60 - AC compressor - Engine compartment relay frame - Pos 4
K67 - Radiator fan, 1st speed Auxiliary fan, 17 DT - Engine compartment relay frame for 17 DT engine - Pos 2
K67 - Radiator fan, 1st speed Auxiliary fan, 17 DT - Engine compartment relay frame without AC - Pos 2
K67 - Radiator fan, 1st speed Auxiliary fan, 17 DT - Engine compartment relay frame with AC - Pos 6
K102 - Parking lockout - Engine compartment relay frame - Pos 8
Sensor
P39 - Bulb control sensor, trailer hitch - Relay frame behind fuse box - Pos 5
Buzzer Relay
Sensor
1994 Model Year
F46 - Heating fan (pollen filter) - Engine compartment relay frame - Pos 3a
F49 - Secondary air pump - Engine compartment relay frame - Pos 11a
Buzzer Relay
K12 - Secondary air injection - Engine compartment relay frame without AC - Pos 7
K12 - Secondary air injection - Engine compartment relay frame with AC - Pos 8
K34 - Radiator fan, run-on - Engine compartment relay frame without AC - Pos 8
K51 - Radiator fan 2nd speed - Engine compartment relay frame without AC - Pos 6/10
K51 - Radiator fan 2nd speed - Engine compartment relay frame with AC - Pos 5
K60 - AC compressor - Engine compartment relay frame - Pos 4/8
K67 - Radiator fan, 1st speed Auxiliary fan, 17 DT - Engine compartment relay frame without AC - Pos 2/12
K108 - Radiator fan - Engine compartment relay frame - Pos 11
K109 - Radiator fan - Engine compartment relay frame - Pos 12
Sensor
P39 - Bulb control sensor, trailer hitch - Relay frame behind fuse box - Pos 1/5
Buzzer Relay
Sensor
1995 Model Year
F34 - Auxiliary fan - Engine compartment relay frame not 17 DT engine - Pos 9a/10a/14a
F42 - Radiator fan (2nd speed) - Engine compartment relay frame without AC - Pos 9b/10b
F42 - Radiator fan (2nd speed) - Engine compartment relay frame with AC - Pos 14a/14b
F47 - Air conditioning - Engine compartment relay frame - Pos 14a
F49 - Secondary air pump - Engine compartment relay frame without AC - Pos 11a
F49 - Secondary air pump - Engine compartment relay frame with AC - Pos 8a
Buzzer Relay
K18 - Fanfare - Fuse box - Pos 6
K102 - Parking lockout - Engine compartment relay frame For X 20 XEV engine - Pos 8
K102 - Parking lockout - Engine compartment relay frame - Pos 10
K108 - Radiator fan - Engine compartment relay frame - Pos 3
K109 - Radiator fan - Engine compartment relay frame - Pos 4
Sensor
Buzzer Relay
Sensor
Fuse Box and Module / Relay Locations.
For most of us long in the tooth owners, this is obvious,
but if you are quite new to Cavaliers, or have never ventured into the hidden depths of the car's electrics before, it may not seem so obvious.
And besides Vauxhall / Opel / GM do not make any effort to keep things simple or even sensible, with every model year and trim level virtually having their own individual configuration / layout.
THE FUSE BOX
The Main Dash Panel Fuse Box is located just below the steering column, behind a pull down flap - This is the one shown in the owners manual and in Haynes.
ENGINE BAY FUSE BOX / RELAY FRAME.
The "Other" Main Fuse Box is in the Engine Bay mounted between the Bulkhead and the Left Suspension Tower. (MOST Cavaliers do NOT have this fuse box).
It is usually fitted to cars with Air-Conditioning, A V6 Engine or Later Anti-Theft Warning System.
DASH RELAY FRAME.
The LEAST known and best hidden Relay panel is the "Relay Frame Behind The Fuse Box".
Access to this is a bit fiddly, as it usually means tipping the bottom edge of the fuse box forward, or removing the whole thing to one side to get to the relay frame.
- There are four self-tapping screws holding the surround / flap assembly of the fuse box, and a wide grey release tab at the bottom. Remove the surround. Un-clip the grey release tab and slide the upper mounts out of their slots to completely remove the fuse box from the dash.
Note that there are dozens of wires attached to the fuse box, and anything RED is permanently live, so disconnect the car battery if you plan to disturb or work on the fuse box.
To make this more of a challenge, there is no clear view of the Relay Frame with the dash still in place -
(I do not recommend removing the dash just for "S#!Ts and Giggles" - once you disturb anything, it usually ends up rattling or squeaking forever after ).
I personally have only touched the relay frame once, to look at the heated rear window relay when looking at retro-fitting electric heated door mirrors to the car.
And this is the best photo that I could get from underneath. Looking up from the footwell past the brake pedal.
Most other modules are well known and written about with the various How 2's and Topics of this forum.
Right Hand Foot-Well / Kick-Panel
Engine ECU (Not all), Central Locking Module, Fuel Pump Relay
Left Hand Foot-Well / Kick Panel
The big X6 main body loom connector.
Factory Fit Alarm in Left Inner Wing (Next to UK Glove Box)
Diagnostic Plug and Octane Plug
Air-Bag / Crash Detector Module
Under the centre console.
THE FUSE BOX
DASH RELAY FRAME.
