Nova_Tek wrote:No idea, first time we've used the plug ever. Wires all look in perfect condition and insulation is 'as new'. With the normal digital clock/temp display plugged in all is well.
Just read this comment, have you tried the computer without the Digital clock plugged in? (DID).
They are not meant to be BOTH plugged in at the same time.
vauxhallnutter wrote:You dont need tech 1 or anything to recalibrate it, all you do is this:-
Disconnect the battery for 10 minutes
Reconnect
Remove fuse (its the one that also controls the hazzards and interior light)
Wait 5 minutes
Put fuse back in
Take fuse out and then put it straight back in again
Dont touch the reset button when in average economy
Go for a drive and it will then settle down and thats it you've calibrated it!
You can then reset it as much as you like!
I will give this a try tomorrow - the fuse is Fuse 8 for interior lights, radio and hazard lights... so make sure you have the radio code if you need it.
I run a full CAN radio, so the code is already embedded between the radio and graphic display.
Do you need the ignition on for any part of this??
as you do not need to remove fuse 22 if the ignition is off.
so if the ignition is off, then it would be like removing the battery for the latter stages you describe...
Reconnect
Wait 5 minutes
Put fuse back in
I did it all with the ignition off so that seems to be the way to go. Found all this out by accident btw! When i was doing the meega sunroof comversion!
Mark
Vauxhall Opel Drivers Club - the friendly club http://www.vodc.co.uk
VBOA Members
the switch is plugged into the connector at the handbrake (plug nearest the drivers seat)
yellow plug as in pics
on the 4th pic notice the dash lights are on
ive had the poss lead off the batt for 10 mins pushed/held the buttons on the switch
now app the comp is working fine i sent it back to the seller and he plugged it into his calibra turbo and all is working (waiting on pics to confim this )
any ideas guys
o and now bought another computer and switch just in case it isnt working afterall
Also.... difficult to see in the photo, but it looks like there is a gap at one end. Make sure the black insert in the yellow plug is pushed fully home in the yellow bit. I have seen these move and when you fit it in the back of the display it goes on one row of pins out.
planetc wrote:Also.... difficult to see in the photo, but it looks like there is a gap at one end. Make sure the black insert in the yellow plug is pushed fully home in the yellow bit. I have seen these move and when you fit it in the back of the display it goes on one row of pins out.
do you mean yhe black part that has all the holes in it or the outer black part i looked again and it does look like the black holes part does look out of line is this correct?
Id only get illumination when no ignition and nothing when ignition on. Only thing I have ever done to this Cav is swap the Red and Yellow wire around on the stereo wiring to get a perm live for memory. But I'm guessing that shouldn't change anything for the trip computer?
scott
I think it should move closer into the yellow surround, you can see the moulded bits that should line up and interlock
I love Robs diagrams, he has so much more patience than I do, lol
cheers for all the help on this thread i hijacked got the comp back and fitted today made sure the yellow plug was correct with no gaps and i can report its WORKING just need to reset/set the time now so how do you do that
