X6 Connector - In the Passenger Footwell
Here is the pinout for the passenger footwell connector as promised.
After hours and hours of trawling TIS and Haynes, I couldn't find anything for pin 45... so I assume that this is the only pin with no connection.
So here goes.
Re: X6 Connector - In the Passenger Footwell
Borrowed from another site,
Here is the layout of the pins in the X6 connector
Sorry to be dense, but what does the X6 do?
Re: Re: X6 Connector - In the Passenger Footwell
lowrider dave wrote:Sorry to be dense, but what does the X6 do?
Pretty sure it's the big one in the ns kick panel, links the front and rear looms.
.... Edit, definitely, I just looked at the image Rob posted.
Peanut_119
Post by Peanut_119 »
regarding this, if my x6 connector is wired up for the heated seats will the rest of the loom b there?
If the wires are in the top plug AND the socket it sits into then yes... if either the plug or socket is missing the wires, at least now you know where the wires should go.
Confirmed - it is the big plug in the passenger side kick panel into which half of the wiring is connected on way or another.
That is - run the wiring from the seat mats to the x6 connector
This is where you need to insert wires if you are retro fitting
Electric sunroof
Fuel Computer
Front Fog lights
and so on, :ugeek:
if the wiring wasn't fitted as standard on your model.
HINT: - Click your mouse on the pin-out image, and it will come up bigger so that you can see it better / more clearly. :D
This should make check control a damn site easier :mrgreen:
Envoy CDX wrote:This should make check control a damn site easier :mrgreen:
MOST of the check control wires go to X6, but I can do a quick trawl and put up a pin-out for that too if you like :ugeek:
just one or two wires that don't go to x6... voltage supply and ground, I think
If your bored enough too :lol:
Think I have most of the wiring here just need to sort the loomage out for it to go in the Cav :)
I enjoy loom hunting and sussing out pin-outs..
yeah I know, I'm odd - it exercises they grey matter :ugeek:
Fair enough :)
