no heater fan and no sound from cd player
happy new year to everyone i have just fixed the cavalier td a went to swap my insurance over last night (online) and because the glow plug relay is not turning the plugs on so to get it going last night i used the good old method of using one jump lead direct to the plugs and hey presto but since i have done that it has developed this problem and one thing i hate is a cold car i have checked fuses and none are blew any help would be really appreciated.
Re: no heater fan and no sound from cd player
Sounds like you've fried something then....
Popped a fuse or two maybe - even if you say they arent blown, change them anyhow..
Blower motor is a 30 amp fuse (green usually).
Interior light probably doesnt work either I'd imagine.
Either that, or you've burnt some wiring or knackered an earth?
yeah i have been told that the dash may have to come out to find the earth the fuses are fine its just freezing because of the time of year lol might just cut my losses and send it to the auto electricians.
Your not far from me, could always have a look at it next weekend if the weathers ok. I assume it still drives?
yeah its fine apart from the cd player and the blower ive found a good side to old cars the blower even when off still provides a small steady stream of heat lol.Envoy CDX wrote:Your not far from me, could always have a look at it next weekend if the weathers ok. I assume it still drives?
yeah i can pop up then if i havnt sorted it your about 20 mins ride away from me. just let me know what time etc
cheers
OK will PM you my number.luketd wrote:yeah its fine apart from the cd player and the blower ive found a good side to old cars the blower even when off still provides a small steady stream of heat lol.Envoy CDX wrote:Your not far from me, could always have a look at it next weekend if the weathers ok. I assume it still drives?
cheers
OK will PM you my number.[/quote]
no bother mate.
no bother mate.
As a pointer for the fuses...
Fuses to check - based on my car (Facelift Petrol LS)
Fuse 4 = 30A (Green Fuse) - Heater Blower fan only
Fuse 8 = 15A (Blue Fuse) - interior lighting, hazards, clock, radio, DID, fuel computer
Fuse 20 = 10A (Red Fuse) - Radio only
I understand that there is a cluster of brown earth wires up near to where the wiper motor is mounted... this is often over-looked when looking for earth tags.
There is also a cluster of earth wires (Brown) up behind the instrument panel, slightly to the left, secured via a self tapping screw.
Most other earth wires are in easy view within the engine bay.
the saloon is fixed now just got to fit a new blow motor and two new rear speakers thanks to everyone for there advice
a special thanks to envoy cdx and his mate sorry forgot your name pal. for taking the time to pull the old girl t bits a get it sorted
cheers if yous need out give me a bell.
No worries Luke. Glad it's sorted!
I'll have that centre section and backbox off soon too!
cheers mate al give you a bell next weekend
