Upholstery seats
Upholstery seats
hey guys
Just wondering, what product is best for cleaning my standard upholstery seats? theyre a bit muggy in a few bits and it bugs me on a sunny day lol. I've seen plenty of products out there but i figured i'd ask some well knowledged people
Cheers guys
Andrei
Cheers guys
Andrei
- jambo_sri130
Re: Upholstery seats
I guess there are loads of products out there but I get decent results from using Fairy Liquid and clean water with a stiff brush. The Fairy Liquid helps too if you need to get wet emulsion out of sofas. haha I learned this when I gave my bro a hand to paint his living room!
Sticking feathers up your arse does not make you a chicken!
I dont like using stiff brushes i have a habit of making the seats bobble, a carpet shampooer is ideal and its one of those things that someone will have stashed away somewhere.
Toying of using some diluted Vanish or Daz & a sponge on mine to see what happens.
So many cleaning products out there these days and some are crazy prices
A bottle of Stardrops (£1 per litre and you only need a few drops), hot water you and a towel or a couple of MF's to soak it up.
You can also use a wet vac if you have one.
I wouldn't bother with car upholstery cleaners as they can get expensive if you get carried away...
Martin.
Martin.
vanish spray on stuff, or even autoglym upholstery cleaner, both good depending on how 'soiled' your seats are
Soiled? :/ few too many wet farts Dan?humbucker wrote:vanish spray on stuff, or even autoglym upholstery cleaner, both good depending on how 'soiled' your seats are
Envoy CDX wrote:Soiled? :/ few too many wet farts Dan?humbucker wrote:vanish spray on stuff, or even autoglym upholstery cleaner, both good depending on how 'soiled' your seats are
A steam cleaner works a treat and all you need is water for the steam cleaner lol
Its what I used on my old astra an it brought the seats up fantastically looked almost new! I would recommend doing it on a hot day though so you can air the car at the same time but help dry them out quicker unless you have a wet vac which I would imagine will also help a lot with cleaning/drying!
[center]
