1992 GSi Project restore maybe
Re: 1992 GSi Project restore maybe
been there, had that, its so frustrating as it was a new pump, and i had overheating problems for weeks before i found out what it was, AdsGray16v wrote:Impeller fell off the waterpump, all stripped down today.
some exellent work going on there mate, cav looks in exellent all round condition,Ads
Cheers Ads, its been a battle but got there in the end, only odds n ends to finish nowAds wrote:some exellent work going on there mate, cav looks in exellent all round condition,Ads
Wow looks excellent
Been out in the Cav GSi most of the day, ABS light keeps showing now and then.
Did some work on the SRi to get it through MOT
- Chip Pan Dan
got a good set of bump strips here, got them off the car the other day
not sure I am fitting any.Chip Pan Dan wrote:got a good set of bump strips here, got them off the car the other day
did you sort the fuel sender and headlining ?
17" BBS wheels fitted
Got to say fella I don't normally light the colour coded look but that looks absolutely stunning big thumbs up from me.
cheers Davegsi dave wrote:Got to say fella I don't normally light the colour coded look but that looks absolutely stunning big thumbs up from me.
Power cap fitted
Still got ABS problems, no light on until the pedal has been operated a few times, the ABS comes in while breaking then after a bit the light comes on.Re: 1992 GSi Project restore maybe
New fuel tank sender fitted and tracking done
BBS looks spot to buddy
Cheers, in two minds on putting it back to original thoughgsi pie wrote:BBS looks spot to buddy
The later system can be read with tech1, the early system is notorious for being a pig to diagnose faults other than wheel speed sensor issues. The tests involve voltage and resistance checks, with which you go round in circles when the fault is intermittent. Check all rings are clean and have good square teeth, use a multimeter to test wheel speed sensors set on ac voltage and measuring across the two pins of the sensor will produce a good voltage that increases with wheel speed. Chances are these are fine if the system works ok initially. If you have changed the pump, along with the solenoid block and the fault is the same then you would be left with a supply/earth issue or a poor connection somewhere within the wiring looms.
well if you sell them
fire me a pm over plz Gary
Going to have a good look at it this weekend, I think its the pump though.planetc wrote:The later system can be read with tech1, the early system is notorious for being a pig to diagnose faults other than wheel speed sensor issues. The tests involve voltage and resistance checks, with which you go round in circles when the fault is intermittent. Check all rings are clean and have good square teeth, use a multimeter to test wheel speed sensors set on ac voltage and measuring across the two pins of the sensor will produce a good voltage that increases with wheel speed. Chances are these are fine if the system works ok initially. If you have changed the pump, along with the solenoid block and the fault is the same then you would be left with a supply/earth issue or a poor connection somewhere within the wiring looms.
Been out in the GSi most of the day, other than the ABS its spot on.
Started putting the exterior back to standard,
front bumper done
rear panel done
door strips next weekend and rear bumper
door handles to follow and slabs
front bumper done
rear panel done
looking good
still tempted on the bbs wheels grr
wheels are here if you want them, in south wales next week toogsi pie wrote:looking good
Wow. I love both of them!
Amazing work, a real credit to you.
