Satin red cav turbo
Re: Satin red cav turbo
fingers crossed! we will await your next report with aniticipation!
Well i was on a roll with this today, managed to get all sensors plugged up, all water pipes back on , all the breathers etc etc. got ecu back in, took it out to look what chips it had, turned out it has "superchips" chips lol.
only thing to do now is, bolt downpipe back upto turbo, refit afm and afm pipe, refit boost pipes. fill up with coolent, sort the 2 leaking fuel pipes. an then its time to see if its alive
fingers crossed for you
Well it runs
for how long who knows ?
havent had it running long but runs well considering it hasent been started in 5 years and has just had the top end off and fiddled with, lifters need to settle back in as there tapping tho it is minor.
after fixing all obvious fuel leaks several others have started. so currently waiting to buy alot of fuel pipe and replace most the piping under neith to see if it sorts it
and check fuel pressure, had a frontera once with a dodgy fuel press reg that was running about 7 bar, leaked all over the place.
http://s229.photobucket.com/albums/ee15 ... EO0082.mp4
still bits to do , and tidy up etc but atleast it starts and is currently leak free !!
good work that man!
