C20ne Vectra A
kriegheim
C20ne Vectra A
Post by kriegheim »
Bought this in september 2011, and have now done some work to it.
Rear and middle exhaust changed.
Angeleyes frontlights.
Now, im repairing water leaks in the trunk.
Plans.
Hood extension
Vectra 2000 front bumper
Some kind of sideskirts
Some extra HP
Changed the rear muffler today, and got 30 extra HP :lol:
No, seriously, the old one was collapsed internaly, and whas almost blocked.
Some pics of it today, off course it started raining, and i hadnt time to dry it enough.
kriegheim
Re: C20ne Vectra A
Post by kriegheim »
and another one
It was getting dark, so the pictures was a little bit blurry
Re: C20ne Vectra A
very clean, nice example
Re: C20ne Vectra A
looking good dude :)
them fk front lights are growing on me :)
kriegheim
Re: C20ne Vectra A
Post by kriegheim »
Gray16v wrote:very clean, nice example
Thanks
gsi pie wrote:looking good dude :)
This isnt FK light, its DEPO. They are pretty much the same, except DEPO costs 150£ and FK 350£ in norway. I reccon black lights fits best with a dark coloured car.
Re: C20ne Vectra A
I think the dark coloured lights look good on the dark coloured car.
kriegheim
Re: C20ne Vectra A
Post by kriegheim »
Fitted the vectra 2000 grille.
kriegheim
Re: C20ne Vectra A
Post by kriegheim »
Need a clean up off loose connectors.
On the backside of the engine hang a lose connector, what is this for?
This is located where the ECU connector is ( paperclip test ) This are spare ones that is not in used, but what are they for?
Mikebmth
Re: C20ne Vectra A
Post by Mikebmth »
I had the same question a while back, mine were just under the cover at the rear of the engine bay and apparently are extra plugs for the 4x4 system on the Turbo etc and maybe standard Vauxhall alarm system.
Most of the higher spec cars shared looms with Gsi / Turbo cars so if yours is a Gls spec or higher you will find random plugs all over the place.
Dont hold me to this but I am sure one of the guys more competant on the Vauxhall looms will be able to let you know for sure.
Re: C20ne Vectra A
Standard alarm wring from the looms of it.
kriegheim
Re: C20ne Vectra A
Post by kriegheim »
Envoy CDX wrote:Standard alarm wring from the looms of it.
Ok, but the one behind the engine is supposed to be somewhere i think?
Re: C20ne Vectra A
Look at the yellow plug behind it, will say 95/91 or 95/98 there will be an 8 pin plug next to that.
kriegheim
Re: C20ne Vectra A
Post by kriegheim »
You are thinking about the RON plug, it is this one
Re: C20ne Vectra A
That is for a 2 pin Oil Preasure sender, that is the wire for the second pin which is a signal wire for an oil preasure gauge on the dashboard which you may or may not have.
kriegheim
Re: C20ne Vectra A
Post by kriegheim »
TurboDan wrote:That is for a 2 pin Oil Preasure sender, that is the wire for the second pin which is a signal wire for an oil preasure gauge on the dashboard which you may or may not have.
Ahh, nice, just bought the oil pressure gauge on ebay, just need another sender.
Re: C20ne Vectra A
What Mike says^
Re: C20ne Vectra A
.... and Dan
kriegheim
Re: C20ne Vectra A
Post by kriegheim »
Will this do?
http://www.ebay.co.uk/itm/For-Ascona-Co ... 1e6c83dcd9
Re: C20ne Vectra A
Yup that'll do it, although you can buy them cheaper
kriegheim
Re: C20ne Vectra A
Post by kriegheim »
Got my turbo lights on
And the gauges fit perfectly, even if they were from a RHD. Some minor scratches, but got them cheap, and a additional cluster came with it.
kriegheim
Re: C20ne Vectra A
Post by kriegheim »
Is there a easy way to take out the box where the gauges are? Or do i have to remove the whole dash?
I think there is a box mounted to the surround, but not sure. Any tips?
kriegheim
Re: C20ne Vectra A
Post by kriegheim »
Just couple of new pics.
Re: C20ne Vectra A
kriegheim wrote:Is there a easy way to take out the box where the gauges are? Or do i have to remove the whole dash?
Its a bit of a sod, you need to pull out the heater controls and the ashtray to get that section out
