Page 6 of 9
Re: 3.0 V6 Cav
Posted: Sat Jan 26, 2013 5:19 pm
by iancav6
humbucker wrote:looking good tho, bet you can't wait to get it running!
Yes its been over a year since it was on the road so really looking forward to hearing that v6 noise again.
Re: 3.0 V6 Cav
Posted: Sat Feb 09, 2013 8:42 pm
by iancav6
Finally got around to machining the cam pulleys to allow me to adjust the cam timing.Repositioned the ends of the slot in the inlet pulleys by 2.5 degrees which should make 5 degrees at the crank.My plan is to set it to std for MOT to pass the emissions test and then reset it.
Belt fitted.
Checking the cam timing.Measured the timing at std,set the cam to the new position and remeasured it, 5 degrees advanced,perfick.
My TDC and valve lift clocks
Re: 3.0 V6 Cav
Posted: Sat Mar 02, 2013 5:26 pm
by iancav6
Finally a bit more progress,having to do some DIY on house at the moment so can only sneak a few minutes on the V6 when MrsCav6 isn't looking
Cam timing set,went for std on the exh and 3 degrees advanced on the inlet,decided just to go for it and see how the emissions test goes.I've now got G spec cams inlet and exhaust.
Cam covers on for good,water pump,starter and crank pulley on.
Bought myself a long nose V6 inlet plenum to test.
Re: 3.0 V6 Cav
Posted: Sun Jul 07, 2013 9:24 pm
by iancav6
After months of little progress on the v6 due to work, diy and holidays I've finally got it ready to put the engine back in.had to weld a couple of patches on the bulkhead which was easier done with the engine out.next weekend should see the 3litre back where it belongs
Re: 3.0 V6 Cav
Posted: Sun Jul 07, 2013 11:26 pm
by HAIRIBO
iancav6 wrote:After months of little progress on the v6 due to work, diy and holidays I've finally got it ready to put the engine back in.had to weld a couple of patches on the bulkhead which was easier done with the engine out.next weekend should see the 3litre back where it belongs
In an omega???
Re: 3.0 V6 Cav
Posted: Mon Jul 08, 2013 5:05 am
by Cavalier342
Looking nice and technical.
Is the layout of that the same as a 2.5? I.e. pulleys and all? Interesting to look at as I've not seen mine "naked" yet on the cambelt side.
Re: 3.0 V6 Cav
Posted: Mon Jul 08, 2013 7:39 pm
by HAIRIBO
Cavaliers had one lay out, Omegas had 3 differnt layouts depending on the age of the engine.
I found this out after buying a 3 bare block years ago, (Last spec) and my cavalier camberlt front and back covers didnt fit. so took ages to buy the ones that did.
Re: 3.0 V6 Cav
Posted: Mon Jul 08, 2013 8:27 pm
by planetc
All very similar though
Re: 3.0 V6 Cav
Posted: Mon Jul 08, 2013 8:31 pm
by HAIRIBO
sure on one type the pully moves from the block to the oil pump
Re: 3.0 V6 Cav
Posted: Mon Jul 08, 2013 10:07 pm
by iancav6
HAIRIBO wrote:iancav6 wrote:After months of little progress on the v6 due to work, diy and holidays I've finally got it ready to put the engine back in.had to weld a couple of patches on the bulkhead which was easier done with the engine out.next weekend should see the 3litre back where it belongs
In an omega???
Would seem an awful waste of a decent engine.
Re: 3.0 V6 Cav
Posted: Mon Jul 08, 2013 10:10 pm
by iancav6
Cavalier342 wrote:Looking nice and technical.
I thought they were all the same,you learn something everyday.
My engine was from a 96 Omega and pretty much the same as the Cav
Re: 3.0 V6 Cav
Posted: Mon Jul 08, 2013 11:56 pm
by Cavalier342
I see. Must be the facelift Omegas then probably had the different engines. Or just depending on model.
Re: 3.0 V6 Cav
Posted: Thu Jul 11, 2013 9:47 pm
by iancav6
OMG,it was sept 29th last year when I pulled the engine out.
Anyway its back in now,all clean and with a new Courtenay stage 1 clutch.
Re: 3.0 V6 Cav
Posted: Fri Jul 12, 2013 11:23 am
by humbucker
How is it running? All good?
Re: 3.0 V6 Cav
Posted: Fri Jul 12, 2013 12:01 pm
by Envoy CDX
humbucker wrote:How is it running? All good?
What he said! ^^^
Re: 3.0 V6 Cav
Posted: Fri Jul 12, 2013 12:59 pm
by iancav6
Envoy CDX wrote:humbucker wrote:How is it running? All good?
What he said! ^^^
I only dropped the engine back in last night,so a bit more work before it running.
If I'm allowed some time over the weekend,should get it done,depends what jobs mrscav6 thinks up for me.
Re: 3.0 V6 Cav
Posted: Sun Jul 14, 2013 7:46 pm
by iancav6
Finished bolting it in today and got it started and ran fine.
took some video of the start up,will post it up once I've figured out how to do it.
Now just got to finish a bit of welding,clean the brakes off and put it in for an MOT
Re: 3.0 V6 Cav
Posted: Tue Jul 16, 2013 5:52 pm
by Adamw5433
Loving the progress on this thread, Ian.
Keep the updates coming mate
Re: 3.0 V6 Cav
Posted: Tue Jul 23, 2013 10:04 am
by John Owens
Superb work Ian ! You must be well chuffed that its running fine after all the work you've put into it . What kinda bhp will it be putting out ?
Re: 3.0 V6 Cav
Posted: Tue Jul 23, 2013 9:15 pm
by iancav6
John Owens wrote:Superb work Ian ! You must be well chuffed that its running fine after all the work you've put into it . What kinda bhp will it be putting out ?
Im hoping for around 220hp and 300nm torque.
Aslong as it does a 13sec 100mph 1/4mile I'll be happy
Re: 3.0 V6 Cav
Posted: Wed Jul 24, 2013 9:26 pm
by iancav6
For the first time in 576 days the cav has moved out of the back garden,last time I drove it was Boxing day 2011.
To celebrate the occasion I treated the V6 to a quick wash.
Re: 3.0 V6 Cav
Posted: Wed Jul 24, 2013 10:08 pm
by belmont_dazz
This is awesome. You need some vids up of it running and moving! I think you'll be pusbing 220hp easily with them manifolds and the omega inlet. What throttlebody/s are you using?
Re: 3.0 V6 Cav
Posted: Thu Jul 25, 2013 12:04 am
by HAIRIBO
If you get the long nose omega inlet to work will you write a how 2 lol, as I have one sitting in my shed.
I prefer the look to the standard c25xe, but if it's easy to convert I'd be up for it.
Re: 3.0 V6 Cav
Posted: Thu Jul 25, 2013 1:12 pm
by iancav6
belmont_dazz wrote:This is awesome. You need some vids up of it running and moving! I think you'll be pusbing 220hp easily with them manifolds and the omega inlet. What throttlebody/s are you using?
Just the std 3 litre Omega short manifold and TB.I have tried various combinations over the years,I did write a post some time ago about the pros and cons of each.
HAIRIBO wrote:If you get the long nose omega inlet to work will you write a how 2 lol, as I have one sitting in my shed.
The C25XE manifold is too small for a 3litre,I picked up over 40 HP at 6500rpm when I switched to a vectra plenum.
The long plenum will need a bit of work to make it fit,I've not mocked it up in the car yet,I suspect the TB will be quite close to the inner wing which may need some thought to get around.
Re: 3.0 V6 Cav
Posted: Thu Jul 25, 2013 3:43 pm
by John Owens
Your gonny upset a whole load of " performance " car owners with that cav of yours ! I'd love to be there to see it lol
