MY CAV 4x4
Re: MY CAV 4x4
"maybe that washer bottle will go now too"
Do you have an alternative lined up? The one on your car is the 'slimline' two-part washer bottle setup.
Re: MY CAV 4x4
I had the same setup on my cav, but i removed it and fitted a stainless power steering tank, that i doctored to fit, dosnt hold a lot of water but it works fine, and it looks a lot better, cant beat a bit of bling, LOL ,theres pics in my WIP thread, Adshumbucker wrote:"maybe that washer bottle will go now too"
Re: MY CAV 4x4
That was the first thing I looked at once it came back....it has to go lol!
Re: MY CAV 4x4
bit of an update on build, got block prepped painted and oil jest finished, crack reground and fitted with ACL bearings, rods and pistons now fitted compression test was 8.06 to 1 so ordered cometic today to get 8.05 to 1 then can get head put on then its ready for going back in.
Re: MY CAV 4x4
new bum warmers!
prob going to have to retrim the rear bench now, or take it out! lol
Re: MY CAV 4x4
They look nice, what are they out of ?
Re: MY CAV 4x4
Good Thread this. Some really nice parts going into it, looking foreward to the next update
Re: MY CAV 4x4
cheers lads, seats are proper recaro cs sportster heated, not out any car, the real deal lol. hopefully car should be running and on dyno end of month so keep looking. im looking forward as much as you guys.
cheers
cheers
Re: MY CAV 4x4
this doesnt really need many words from me as im sure the pics will say enough...enjoy!
Re: MY CAV 4x4
Alot of money been spent here, TOP STUFF!
Re: MY CAV 4x4
Out with the old and in with the new!
Re: MY CAV 4x4
btcctroy wrote:You must have a serious budget.
Had a serious budget you mean!!
Re: MY CAV 4x4
Looking somewhat special there!
Re: MY CAV 4x4
Lovely job, Darren. Did you have custom rails made for the seats?
Re: MY CAV 4x4
had to have fabricated some adapter plates and modify the car brackets to make them fit, but all works good and retained both height adjustment and slider action plus works with stock pre tensioner belts so nice and safe.
Re: MY CAV 4x4
seriously getting there now, engine almost complete now with freshly painted rocker cover and carbon spark plug cover to finish it off, a neat little rose jointed turbo brace with milled aluminium block (looks sweet!) soon fitted and then the last bits of work to be done cooling wiring of ecu etc.
more to come soon!
more to come soon!
Re: MY CAV 4x4
So alot more completed now and soooo close to being back in the car!!!!
more to come very soon!
Re: MY CAV 4x4
removed indicators from the front strip and retro fitted them inside the outer headlights and also refitted the inner lights as side lights and mainbeam to outer, all using H4 bulbs to BRIGHTEN things up a bit, then fitted omega washer jets until i have it welded and painted in the near future, not a bad cover up feature for now ha ha
Re: MY CAV 4x4
The front looks 100% better, Them seats and that engine look awesome
Re: MY CAV 4x4
So....update time, im sure yous are wondering whats been happening so here goes..
Mocal sandwich plate onto the Z20LEH oil pump, braided hoses to oil cooler and moved the positioning to accomodate larger fan for radiator.
gearbox and transfer box back on and engine mounts arrived from germany! ready to drop back in
Engine back in turbo and manifold back on and shiny dewis inlet on with an Omex 3.5 bar FPR all using dash6 union fittings
New roose motorsport hoses to sort cooling out
Decided it was time to up the boost pipe diameter to 70mm for big power
old for new
mock up pipe fit ready for welding to keep as much hard pipe as possible rather than the scruffy hose and clip overdose as seen on many, and all roose pipes fitted.
ECU being fitted today so hopefully a turn of a key is just around the corner!
old for new
Re: MY CAV 4x4
Exellent work Dycie, looking forward to seeing this at RR event
Re: MY CAV 4x4
Top work, Darren. What mounts are you using? Also, what bottom pulley is pictured? I'm liking that a lot!
Re: MY CAV 4x4
Just standard mounts Dan, new ones ordered from Germany, I still wanted it to feel a nice drive. Bottom pulley I will check the Morra for you.
