vauxhall cavalier 4x4 turbo
Re: vauxhall cavalier 4x4 turbo
tbh dude
stuff main dealer parts they be £££,
use your head and to a hydraulic specialist and get a pipe made up youself
i did this when doin my lockeed 4x4 system went and had all my bypass pipes made by pirtek
as i couldnt use any old pipe to do this
just and idea for you tho buddy
i would but dont have 1 near me and need car on road for my work so been pming folk on fb see who has spare kicking aboutgsi pie wrote:tbh dude
Yes the genuine vauxhall pipe would be nice but you can just use any old bit of pipe, trust me it will probably outlast the rest of the car. I've used bits of normal pipe on many turbos now and there still going strong. Just make sure theres no kinks in it.
been told best bit to use is petrol pipe or sumething simler
been told to try the breather mod as well just been trying to find a how to on it
thats the problem Dan, i used a bit of ordinary pipe on my gsi turbo a few years back, and i carnt remember if if kinked or burst, but i had oil all over the place, and to be honest i dont think the dealer part was that dear, only my opinion but i would use the proper pipe for peace of mind, if nothing else, AdsTurboDan wrote:Yes the genuine vauxhall pipe would be nice but you can just use any old bit of pipe, trust me it will probably outlast the rest of the car. I've used bits of normal pipe on many turbos now and there still going strong. Just make sure theres no kinks in it.
does vauxhall still stoke turbo parts thou was told to try place in tv as they have few turbo parts in stoke well so i been told
ps ads no pm form you yet cheers
Pm sent Stephen
To get him going for now though abit of pipe will do until he can get hold of a proper pipe.
Oh and the breather mod is dead easy. Wip the rocker cover off, turn it upside down and youl see a metal plate secured on with aload of bolts, take this off and cut most of it off and just leave about 4inchs on under where the breather pipes enter. Put that little bit back on with the bolts and bin the rest, then put rocker cover back on. Done!
Cheers will be doing work on it next 3days hopefully picking new bits up tomorrow of a dead hatch I have found. ( Folk on fb know what 1 I mean )
Swap the bootlids over
stephen, i will give you a good tip, if and when you do change the hose from the bottom of the turbo to the block, only connect the hose to the bottom of the turbo first, then turn the engine over until you get oil comming out of the other end of the hose, then couple it to the engine block,this is to make sure the turbo is primed and you have oil flow, if you dont have the oil flowing through, you will fry your turbo, Ads
cheers ads realy need to get pipe checkt as its now leeking bad so deff need to change it now
humbucker wrote:Swap the bootlids over
spare 1 a hatch mine a saloon and my boot lid is fine
unless you know about spare saloon shell that my neiboure is picking up next week
Steven have alook at the first 2 pages of my WIP thread for the Breather mod, there pictures and info of when i did mine.
sound like it breathing heavy to me.
why so much blow by,
oil in pipes, pipes blowing off. just not normal
if its a dirty engine i wouldnt use flush, it can released debris which can block the pick up pipe. seen it happen
Pickt new bits up fitting on monday ass will striping front end to get to leek tomorrow
Stripping front end to get to the turbo return pipe? You wont even need a jack if you parked it half on a curb! One screw driver is all you will need, a 5 min job.
me too, turns to something closely resembling the consistency of sand in the sumpcavbtcc wrote: if its a dirty engine i wouldnt use flush, it can released debris which can block the pick up pipe. seen it happen
tried that hes to low at front and 1 cublee clip faceing wrong way and a bitch to get into it want to tidy up in that bit plus new bits going on as wellTurboDan wrote:Stripping front end to get to the turbo return pipe? You wont even need a jack if you parked it half on a curb! One screw driver is all you will need, a 5 min job.
http://opeloem.com/vauxhall/cavalier_19 ... ngine.html
Vauxhall, Cavalier 1989-1995, Fuel and exhaust, Turbocharger, C20Let Engine
number 15 i will be replacing
ok also checkt vin plate says adam opel this mean its a opel shell fron germany ????????????????????
7mm ratchet works well for difficult to get to areas.
You do realise you could see blue smoke reconnecting all these pipes.
See Wat happens I guess
found leek its defo from pipe bottom of turbo going to sump
is it a speacial pipe for it as its a normal pipe from what i can see
The pipe will have a special lining made to withstand oil and normal pipes dont have this. But like i said if you just want to try it for a quick fix then any old pipe will do but get a proper one ordered asap!
