Well, I've been at it again...
playing with the Cavs wiring
I have a week off from work this week, so I am able to spend some time on the Cav without too many distractions.
So yesterday (Monday), I decided to rip out all of my dash (instrument panel, heater panel (Display panel in my case) and the glove box.
The reason for this is a new ruling in the MOT relating to unidentified Cabling.
So I thought that I should re-wire in my oil pressure sensor and speed tranducer in the engine bay. I also fitted the nice shiney speed transducer that arrived with my recently fitted replacement Astra GTE digi-dash.
I stripped apart the ECU loom from the C18NZ set-up, and used all the black plastic sleeving to make the job look "OE".
Then I fed this wiring into the cabin via the hole left by the removal of the mechanical speedo cable the other year.
Whilst I had the dash out, I also decided to wire the fuel computer in properly.
I connected everything up, and found that the fuel computer stalk worked fine
Then I took the car for a spin before putting all the instrument hood panels back... This was just as well, as the speedo registered too low a speed.
I flicked the red switch to position 2 on the top of the digi dash, and an accurate road speed was now displaying.
The shrouds and trim panels were all refitted.... but this wasn't the end of the speedo saga - I will go into his in a moment.
I then removed the ultrasonic module from my Meta alarm, because it consistently triggered the alarm if I didn't turn it off via the fob.
I then dropped out the relay frame (behind the main fuse box), to identify which relay needed to be re-wired to wire in electric mirrors.
There is a black/white wire on pin 5 of the beige heated rear window demister relay.
I left this hanging about, and ventured indoors to do other jobs..
