Cavalier Trackcar Project
Re: Cavalier Trackcar Project
Because the pic he put up is an astra. And mines not fitted to the car at the moment.
- joe cavalier sri
so how would you do that to a cav without the subframe ? may sound a daft question but its intresting and im trying to understand cavs more inside and out
Please read the whole thread before replying and you may stand a chance of understanding then.
He wasnt showing me the suspension/subframe setup.
- joe cavalier sri
The bar welded in between the steering rack mounts is a commonly done on older Vauxhall track cars without a subframe.
1984 Opel Manta 1.8S - 1987 Mk2 Cavalier SRi C20LET - 1989 MK3 Cavalier SRi V6
I bought a new toy to play with
Its a 16ton Hydraulic Pipe bender with 8 differant sized formers:
As you probably guessed allready its so i can make the rollcage inside. Its more than powerfull enough for what i want. It can bend upto 3" pipe! Just need some pipe to bend now...
haha, where is the 'like' button!
Nice bit of kit, think you might have a que forming
Why are you first in lineplanetc wrote:Nice bit of kit, think you might have a que forming
Maybe a few rear half cages could be made up and sold.
as I said im wanting rear cage
But because mine is stripped out its not going to be a good car to model them on as most people will want them to fit with the seats still in. Maybe troys car would be good to use as a template.
Also the gsi floors may be slightly differant where it would mount. Would you want one to bolt in or weld in pie?
bolt in is poss plzz dan
hmm would a gsi be different in that way?
May not be different at all as the sills and rear bulkhead are the same. You would need to weld the bolt on brackets into place though pie
Will see how mine goes first and go from there. Just waiting on some prices for some tubing.
that's not a problem troy
Yeah sure, I could fit one in the wifes Zafira just in case she overdoes it on the roundabout down the road that she spends half her life going around!! I will certainly remember that Dan has the kit though, if I were to ever have the time and funds available to join the club here!btcctroy wrote:Why are you first in lineplanetc wrote:Nice bit of kit, think you might have a que forming
20 metres of CDS Tube on its way! Should be here by friday
so much for 'dont think ill buy the tube this month' hahaTurboDan wrote:20 metres of CDS Tube on its way! Should be here by friday
Was a good deal...
Yes a very good dealTurboDan wrote:Was a good deal...
Not done much recently but today i did manage to have an hour or so on it.
Made a start on the rollcage feet, done the front drivers side:
I also tried out the pipe bender on abit of tube i had left from the engine bay. Just wanted to see if the pipe would kink or not as some of the benders have a habit of kinking them rather than actually bending nicely. But it worked well, bent it as far as it would go and its still perfectly round all the way round the bend which is good:
the box section looks cool
What thickness did you make the feet Dan?
