my gsi work to date
bigsilver
Re: my gsi work to date
Post by bigsilver »
http://s921.photobucket.com/user/bigsil ... ml?filters[user]=138842521&filters[recent]=1&sort=1&o=16 that the cavy all undersealed black floor, white chassis,red crossmember ,the first thread at top of page is slide show if u cant see this thread
bigsilver
Post by bigsilver »
http://s921.photobucket.com/user/bigsil ... ml?filters[user]=138842521&filters[recent]=1&sort=1&o=0 subframe back on
Ads
Post by Ads »
must be something wrong with the links mate, I can not access the pics, Ads
bigsilver
Post by bigsilver »
Not sure whats up mate, if u go to first thread on page 1 theres a slide show, dont understand how its not posting, posting onto first thread, sorry m8
Ads
Post by Ads »
excellent work mate, looking really nice under there now, I can appreiciate all the work that has been done to the underside as I done my cav turbo the same, didn't need any welding as it is solid, but it was taken back to bare metal, rustproofed, undersealed, and running gear done silver, anyway mate a good job, keep it up and keep posting the pics, it will all be worth while when its all done mate, Ads
bigsilver
Post by bigsilver »
Thanks very much m8, im gonny link everything back up on sunday, ive replaced nearly everything, no rust or soft metal anywhere now, the chassis is untouched except a small hole at front engine mount, just need to get the just for men noo lol, still needing few small parts that I burnt when welding, schoolboy lol
bigsilver
Post by bigsilver »
http://s921.photobucket.com/user/bigsil ... %20Uploads spax bilstiens amd brakes all linked up, looking for Brown plastic on driverside rear that seatbelt slots thorough brown in colour slso back seat, caught fire
bigsilver
Post by bigsilver »
http://s921.photobucket.com/user/bigsil ... sort=3&o=1 tank and exaust back on
bigsilver
Post by bigsilver »
http://s921.photobucket.com/user/bigsil ... ml?filters[user]=138842521&filters[recent]=1&sort=1&o=3 finally got her of the stands after a year and 3 months, all the work has been done underneath, absolutely splid and tight with no rust or signs of soft metal, she is on spax 60mm, just the rubbing down to do then full tespray
bigsilver
Post by bigsilver »
Noticed hasnt posted again, click on first link shpuld take u in
bigsilver
Post by bigsilver »
Cracking pictures! and progress. :)
Were you wanting the pictures linked individually on here?
bigsilver
Post by bigsilver »
Cant seem too see them now, has it been removed
bigsilver
Post by bigsilver »
Wasnt to bothered, was getting problems loading, so I can show my progress, can u see them ok because I could at first now I cant, regards tam
bigsilver
Post by bigsilver »
bigsilver wrote:Cant seem too see them now, has it been removed
I can see the links to your photobucket page - what is it you're trying to do?
bigsilver
Post by bigsilver »
I thought ppl couldnt see the photobucket page so I post anothwr link, if its a problem to u just delete them
Ads
Post by Ads »
that looks brilliant work mate, love the white underpan etc and the red running gear, i think thats thr only one ive seen that looks cleaner than mine underneath, Ads
bigsilver
Post by bigsilver »
Thanks ad, ive spent a lot of time on her, hopefully get her on the april road round about march
bigsilver
Post by bigsilver »
bigsilver
Post by bigsilver »
Got my morettes at last, as above:-)
bigsilver
Post by bigsilver »
bigsilver
Post by bigsilver »
Got opel2 adapter and connected to 89L, I can get live data ftom enginemanagent bit cant seem to get into abs when I click it, just saying no communication, turn key off for 20 srcs and turn back on, but still nante, as above post, any info a help
Year? Early abs is not obd compliant
This is the general listing for the ABS Modules.
To carry out a flash code diagnostic of the ABS system, short pins A and K on the diag plug and then turn on the ignition (engine not running).
If there are any stored fault codes, then the ABS Tell-tale light should flash out a two digit numerical sequence.
Early models which have the old ABS system where the control unit is located at the side of the passenger seat in a lump in the carpet do not usually have this fault code facility.
Check whether the diag plug has a wire at location K.
16 LH Front Solenoid ( Relay & Connections )
17 RH Front Solenoid ( Relay & Connections )
18 Rear Solenoids ( Relay & Connections )
19 Solenoids Relay Circuits
25 Faulty Sensor toothed Ring
35 Pump Relay Circuits
37 Stop Lamp Switch ( Pedal Switch )
39 LH Front Speed Sensor ( Air Gap & Operation )
41 LH Front Speed Sensor ( Resistance & Connections )
42 RH Front Speed Sensor ( Air Gap & Operation )
43 RH Front Speed Sensor ( Resistance & Connections )
44 LH Rear Speed Sensor ( Air Gap & Operation )
45 LH Rear Speed Sensor ( Resistance & Connections )
46 RH Rear Speed Sensor ( Air Gap & Operation )
47 RH Rear Speed Sensor ( Resistance & Connections )
48 System Voltage High/Low ( Alternator & Battery )
55 Faulty ECU
