James' 1995 Manual CDX V6 Saloon
Re: James' 1995 Manual CDX V6 Saloon
Then came the moment of truth...
Did my repair panels fit?
Well apparently they fitted very well indeed.
Gold star for Rob
Once fitted, and the welds were fettled.
A nice coating of epoxy mastic, before some sort of colour coat later.
There was also an area rear of the large flat repair panel that was a bit scabby.
After ensuring that nothing was loose or too flakey, I covered the area with Vactan.
See left side of middle picture.
From what I can tell, my work on the Cav is done until we are ready to refit the rear bumper and boot interior.
(As with any car repair thread - that was a very naive and stupid thing to say - of course I had not finished yet).
It is now all Troy's territory.
Gold star for Rob
23rd November 2022
A bit more from me -
my job was to paint the epoxy mastic with a colour coat.
It is in fact Rustoleum direct-to-rust high adhesion black primer.
So good enough as is, or equally good if Troy paints over in the body colour.
So here are the pics...
The boot floor
The Underneath
And the outer wing.
More installments to follow:-
The boot floor
The Underneath
And the outer wing.
25th November 2022
Okay, so Troy had been a busy boy.
With the panel welded in.
Doing a bit of panel beating when I arrived.
He was blending out the distortion caused by welding in a close-fitting panel.
A skim of filler to identify high and low patches.
No doubt his OCD will have him spending almost all week getting the finish closer and closer to the level of perfection that he expects.
So outside -
And inside - now minus a big hole.
Just so you know, we both checked the fit of the rubber filler neck liner to the hole in the new metal oriface.
A good fit - for info, the hole for the filler is 87mm diameter.
I measured it previously to confirm that my masking tape template was correct.
Troy measured it to confirm fitment to his finished repair panel.
So outside -
30th November 2022
Just when I said my work was done on the cavalier, I was given a few more jobs to do.
First was to remove the casing from the driver's door mirror.
Troy says he struggles to release them, but a quick review of my How 2, meant that this was only a two minute job.
There is a lot of paint and lacquer peel. So I will be prepping this later.
The problems with the mirrors is fitting them back onto their spring catches.
They need a good thump to clip them back into place, but it is far too easy to smack them too hard, and crack the casing...
Then there was - "investigate bubbles on the off-side rear arch".
Ooops, here we go again.
Rust galore.
And new repair pieces for the win.
Inner...
And outer skin.
Troy says that they look brilliant.
Apparently he will have me welding soon...
Don't worry James, I assume that will be on my van.
Rust galore.
Inner...
And outer skin.
2nd December 2022
Here we go again...
First job tonight was to repair the scabby rear suspension tower.
As you can see to the left of the picture, quite scabby.
Scabby patch cut out...
Outer reinforcement piece cut out with the scabby part.
The scabby metal virtually fell off the reinforcer as I cleaned it up. Just two very strong spot welds that needed to be ground off.
Replacement panel for the tower skin.
As you may be able to tell in the pictures, I was sat in the spare wheel well with a body saw and angle grinder doing the cutting, cleaning and photographing.
I had to unbolt the rear damper to get better access to clean up the edges of the hole.
Rear beam resting on an axle stand to stop the spring popping out.
Now the older job.
The driver's door mirror with galloping paint and lacquer peel.
Now totally devoid of paint.
Sanded with a d/a sander and 180 grit paper.
Ready for it's proper paint,
Plastic requires a proper adhesion coating, not just generic primer for the paint to "stick" properly.
(so I am told - lol).
Here we go again...
Now the older job.
7th December 2022
Righty-oh...
A bit of filling, flatting, and smoothing of the repaired wing.
Getting very close.
Also a few bits of the arch given a bit more attention.
Here is a picture of the hole in the inner arch, and the rust-treated chassis rail and trailing arm.
At the end of the evening, Troy welded in the inner panel for the inner arch / suspension tower.
My first job in a few days will be to clean up the welds and give a quick blast of weld-thru primer.
The thicker support panel will need a quick bead-blasting to clean any light surface pitting before that is ready to be welded in.
Righty-oh...
Getting very close.
9th December 2022.
And tonight's instalment...
First job was to remove the whole off-side tail light assembly - ready for when the wing gets painted.
(10mm socket on the four hex-head self-tapping screws).
The remainder of the night was mainly the completion of the suspension turret / inner wing repair.
On Tuesday, the inner skin was welded in.
Tonight,
1 - the welds were cleaned up both inside and outside.
2 - The outer face painted with weld-thru paint / primer.
3 - The reinforcer was cleaned in the bead-blaster cabinet, to remove any remnants of corrosion and pitting.
4 - Again - weld-thru paint on the face to be tacked onto the inner skin.
5 - All welded up,
6 - Cleaned and painted with Epoxy-primer mastic paint.
A good solid, tidy job.
The pictures in sequence -
Inside the boot...
Inside the wheel arch...
And a previously unseen picture of the inside of the fuel filler hole.
Ignore the piece of cord from a power file sanding belt.
As there is work to do near to the rear door aperture on the arch, it was agreed to remove the rear quarter glass.
Very easy, once the inner trim is removed.
Four white plastic trim clip / rivet-thingies like those used on the door cards.
One torx screw (t25 screw-driver).
and the upper seat belt mounting bolt.(21mm hex socket).
A whole lot easier on the saloons than on the hatchbacks... (well over a dozen t25 torx screws to remove, to take out the rear speaker shelf, load area trims etc...)
The quarter-glass is held on by four plastic nuts.
(9mm hex socket).
Tonight,
5 - All welded up,
Inside the boot...
(9mm hex socket).
23rd December 2022
A lot more progress from Troy today.
When I arrived, the arch had been cut open to expose the rusty middle layer...
This had now been cut away to leave only good solid steel.
As you can see, the inner skin had already been repaired a few days ago.
Whilst I was oblivious getting nowhere faffing on my van, Troy had turned into the fabrication and mig robot...
Two hours later, at the end of the night, all three skins were made up, welded in and tidied up, ready for body prep.
Even on close inspection, the hand made repair piece looked like a perfect factory part
Awesome work.
Awesome work.
4th January 2023
The body has been getting a bit more love over the past few days.
Troy is almost at the point where the word primer is being mentioned.
And I know that the top coat colour has also been ordered.
So this is the state of play....
As for me... last week I refitted the rear off-side damper, so that there is less to do, and also so that the car can be rolled back into the spray area.
So fingers crossed, no more cutting out or welding to do.
Just paint and rebuild.
6th January 2023
End of play tonight.
.. the "rough" primer coat.
the starting point, from where all following coats will be dressed to maximise the final finish.
Amazing how well the look improves when it is all one even colour.
Then...
14th January 2022
Slowly but surely...
Sanding of the primer level is complete.
Then...
14th January 2022
25th January 2023
As I arrived last night, the rear wheel was being put on, and the fuel filler had been re-installed.
The plan was to start the car and then after Troy was happy with that, we were going to reverse it into the spray booth area.
Unfortunately we spent close to three hours going through the ignition system looking for a non start issue.
The front bank of plugs (2, 6, and 4) and their bores were very oily...
Badly leaking seal somewhere?
All mopped out, plugs cleaned... still no joy.
Swapped the old coil pack back in... no change.
Continuity and resistance checks found both coil packs to be okay, returning approx 11k ohms on each winding.
(Well within tolerances).
Eventually after some googling Troy found an ignition amplifier on the near-side wing under the P.A S. fluid reservoir.
Pin 4 of this was heavily corroded.
Checking continuity found no continuity to earth / ground. - even after cleaning.
Our suspected diagnosis is a defective ignition amplifier.
Being a V6, it has 7 pins, so not as common as the typical 4-pot, 5 pin amplifier.
To add further insult to injury, there is quite an oil leak from the sump area.
Fingers crossed for some positivity soon
28th January 2023
After fitting the new amplifier module, the car lives!!
Now idling quite smooth I believe.
1st February 2023
The car was reversed into the spray area, however due to a poor paint colour match by the mixers (not enough blue), the car was obviously not painted.
The near-side mirror casing was removed, as this will be used by a different paint supplier to match the paint to the correct combination.
I elected to put everything back together in the engine bay.
First was to refit the ignition amplifier back to the inner wing under the power steering reservoir.
A bit of a bugger to get the screws in so I moved the coolant header tank for better access.
I initially released the top hoses, but realised that this was not necessary, but I am happy that I did, because I found the stub reinforcing liner to be sticking out a long way from the stub.
This was gently tapped back into the stub.
Then all the air-trunking was refitted. It is redundant due to the alternator not requiring an external cooling fan, but the trunking keeps the original look.
The battery terminals were tightened and the battery clamp bolt replaced with a new one, as the old bolt had a virtually stripped thread.
I found a button-head screw to fit the plastic cylinder head cover. Not a perfect match, but now all four corners are securely located.
So here we go - fully assembled.
At least that is the engine-bay work 'boxed off'.
1st February 2023
8th February 2023
The car has been put back together.
Engine Bay -
I refitted the battery cover, so the engine bay is complete.
Interior -
I refitted the off-side rear quarter glass,
the rear quarter interior trim and a new buckle cover.
Interior complete.
Boot and Rear Bumper -
The boot interior trims, carpet etc; were all fitted.
I forgot how tight a fit that plastic rear valance cover is.
All done now though.
And the rear bumper finally attached.
Off-Side Rear wheel -
The wheel nuts torqued up and the centre cap refitted.
That just leaves one job for Troy to do tomorrow.
The fuel filler cap and rubber filler liner.
Then it is job done.
I lied - I have one piece of boot trim to refit on the off-side of the little hatch behind the rear seats...
Engine Bay -
Interior -
Interior complete.
10th February 2022
In the absence of Troy, I did the last couple of jobs on the car.
First - replace a grommit in the boot floor.
For extra security, smeared with a bit of black sealant.
Then fitted the trim at the rear of the panel behind the rear seats.
The rubber filler neck gasket / liner next.
What a total bugger to get the flange over the bodywork with the filler pipe in situ.
And finally the filler flap.
A quick check for functioning of the lights found a sticking rear fog light switch.
The hazard switch was initially a bit sticky, but free'd off and worked properly after a few actuations.
18th February 2023
Unfortunately, the car failed it's MOT.
Two bits of welding -
off-side sill,
Front footwell.
Then non-welding stuff -
Hand-brake travel (insufficient reserve)
Swivel pins or bushes - excess wear - rear axle (both)
Leaking exhaust tail-pipe joint
And emissions...
So some interior stripping beckons...
off-side sill,
Front footwell.
And emissions...
22nd February 2023
When I arrived tonight, Troy had already done the off-side rear sill.
It looks like he had been busy again.
Next job was to do the rear brakes - excessive handbrake travel.
The off-side (driver's) handbrake was set about right.
The near-side was not very effective.
Being a bit of a veteran at these things, Troy had the cable adjusted up so that full wheel-lock was achieved with six clicks on the lever, in less than ten minutes.
Next job - I unbolted the front of the driver's seat just enough to get the carpet and underlay out of the way.
Protected by a piece of sheet steel and a fire blanket, the hole just forward of the driver's seat was repaired.
All welded up, cleaned and painted inside.
Whilst he did the repair panel and welding, I removed the exhaust.
It came apart quite easily, the centre section was quite a loose fit in the tail-pipe.
It didn't look like much exhaust paste had been used originally
I cleaned up the joint faces and then re-sealed with 300°C silicon sealant.
Re-assembled and tightened up.
I managed not to shear the exhaust clamp U bolt.
Note the fancy-pants hanger-rubber retaining clips.
Whilst I was under the car, I also loosened the rear beam pivot bolts ready to drop the beam when the bushes have arrived.
The near-side bush was tatered. Lots of movement of the beam.
Last job was to test the exhaust.
The car is still a bit reluctant to start, but once it is running, it is quite happy.
I am pleased to say no leaks, but still quite a fruity note.
Because of my OCD, I made sure that the tail pipe was straight / level.
Last job tonight was to paint / underseal the exterior of both repair panels.
Other than the rear beam pivot bushes, it looks like we have sorted everything else listed on the fail sheet.
blimey, someone's had their weetabix
What a good write-up, I haven't seen this level of cav work for ages
Cant believe how fast you've moved it on, looks awesome level of finish too.
Really feel for James having to sell his house, my fixed rate mortgage is due to expire in August, if I hadnt over paid it when I couldn't spend much during lockdown, I'd too probably have to consider selling up. Its still going to really hurt.
Hopefully the cracking job on the Cav will help ease the pain.
It has been about three or four months from end to end - during evenings after work for both of us.
Plan is for the bushes to be fitted, and get that elusive piece of white paper before the end of the week.
Fantastic!
