Page 4 of 13
Re: James' 1995 Manual CDX V6 Saloon
Posted: Sat Aug 27, 2016 5:36 pm
by humbucker
Eek! Don't worry, there's probably nothing to worry about if the car has sailed through its MOT.
Posted: Sat Aug 27, 2016 5:49 pm
by humbucker
Is it a requirement to change the dryer when replacing the condenser? I've just bought a new condenser for my MV6 (update to follow) and thought I might be able to use the old dryer. I'm not so convinced now that I've seen your post and had a scout around other forums for info. Only about £30 for the replacement part, but can do without shelling out unless I have to.
Posted: Sat Aug 27, 2016 7:09 pm
by James McGrath
humbucker wrote:Is it a requirement to change the dryer when replacing the condenser? I've just bought a new condenser for my MV6 (update to follow) and thought I might be able to use the old dryer. I'm not so convinced now that I've seen your post and had a scout around other forums for info. Only about £30 for the replacement part, but can do without shelling out unless I have to.
You're supposed to do it but I don't think it's a necessity.
Posted: Sat Aug 27, 2016 7:42 pm
by James McGrath
Right then.
Here is the dash with clocks removed, oh look, wires.
As we can see, bulb number 19 is missing, yay!
Essential supplies from Halfords:
Turned the engine on and sure enough, the light is permanently on.
This is extra specially annoying as the MOT is due on the 7th so I have to get this fixed by then.
Clocks back in place:
Time for a paperclip test!
I'm getting 3 codes and luckily they are all easy fixes.
13 - O2 sensor, had this one before.
14 - Coolant temperature sensor, that might explain why it overheated!
16 - Knock sensor rear bank, I'm hoping this is easy to get to.
All in all, not what I wanted to see but it could have been worse.
Posted: Sat Aug 27, 2016 8:39 pm
by James McGrath
Hang on, just rechecked it and it's code 144 not 14.
144 is no immobiliser signal.
Which makes much more sense as it would be a bit odd to remove the dash light just for some sensors.
My guess is something went wrong with the immobiliser years ago, couldn't afford/be bothered/couldn't get hold of parts so removed the dash light.
Since then the O2 sensor and knock sensor have packed up but as there was no EML light there was no way of knowing.
Anyway, I've already ordered an O2 sensor and a knock sensor, both Bosch parts, which I'll fit when they arrive.
Now I've got the delightful job of finding out what's wrong with the immobiliser.
I remember how much trouble Dave had with that on his V6 so I'm not looking forward to that job.
Posted: Sat Aug 27, 2016 10:53 pm
by humbucker
On the plus side, the knock sensor is easy enough to fix, although IIRC, the required routing of the wiring means that it needs to go in and around the alternator in order to be protected by the rear heat shield. I replaced the same part on my V6, was an 'under the car (and lots of swearing)' job.
Posted: Sun Aug 28, 2016 3:27 pm
by James McGrath
Yeah, hopefully I can do those two jobs myself in time.
I know someone local who is good with electrics. Hopefully they an diagnose what's wrong with the immobiliser.
Posted: Thu Sep 01, 2016 8:07 pm
by humbucker
The new issue of Straight Six News arrived on my doorstep this morning. There's a nice pic of your V6 included in the magazine's VBOA National Rally coverage.
Posted: Thu Sep 01, 2016 8:39 pm
by James McGrath
humbucker wrote:The new issue of Straight Six News arrived on my doorstep this morning. There's a nice pic of your V6 included in the magazine's VBOA National Rally coverage.
Awesome! Is there any way that I could get a copy?
Posted: Thu Sep 01, 2016 8:41 pm
by humbucker
I'll send you mine if you like. Drop me a PM with your address.
That's your car appearing in two magazines in as many months! Where will it pop up in October?!
Posted: Fri Sep 02, 2016 8:05 am
by Lowrider Dave
humbucker wrote:There's a nice pic of your V6 included in the magazine's VBOA National Rally coverage.
Nice! Mine never got in print! Good luck with those sensors.
Posted: Fri Sep 02, 2016 7:23 pm
by James McGrath
Well, it's booked in for an MOT on Monday and neither part has arrived yet.
I'm beginning to panic now, I don't think it's going to pass emissions without that O2 sensor.
Posted: Sat Sep 03, 2016 12:09 am
Here's hoping for a Saturday morning postal parcel.
These last minute panics keep things interesting.
You'll be fine.
Posted: Sat Sep 03, 2016 7:55 pm
by James McGrath
You were right Robsey, post! Hussar!
Right now I've got to get them fitted after work tomorrow before it gets dark.
Posted: Sun Sep 04, 2016 11:59 pm
by James McGrath
Right, the O2 sensor is on!
I sprayed the old one with WD40 last night in preparation.
Obviously it did the trick as it came of without a fuss.
Here's hoping it's enough to get it through the MOT tomorrow...
Posted: Mon Sep 05, 2016 12:38 pm
by Lowrider Dave
Fingers crossed.
Posted: Mon Sep 05, 2016 7:15 pm
by James McGrath
Bugger...
Posted: Mon Sep 05, 2016 7:23 pm
by tonyo
Oh... What's the score?
Not too bad I hope..
Posted: Mon Sep 05, 2016 7:36 pm
by James McGrath
Funnily enough nothing that I thought it would be. The emissions were fine thank god and the EML light is just an advisory.
It failed on:
-Number plate lamp
-N/S indicator repeater
-Battery insecure
-O/S Headlamp aim - This is the headlamp itself not the aim, basically I need a new one.
-Radius arm ball joint dust cover
Advisories:
-EML light
-Exhaust gas leak from the back box
-slight oil leak
-N/S rear tyre worn on inner edge
All niggly things really. Still annoying though.
Posted: Mon Sep 05, 2016 9:05 pm
by tonyo
Bulbs and headlamps are easy tasks..
Battery insecure? Hmm, has it lost the clamp?
Radius Arm Dust cover.. In English, I guess is the lower balljoint. Two options there then, either a new lower arm or repalce the balljoint. Not too hard.
As you say, all niggly..
Posted: Mon Sep 05, 2016 9:10 pm
by James McGrath
Yeah, the bolt that holds the little battery clamp plate thingy in place broke when I tried to unscrew it a few month ago.
I had forgotten about it until today.
I still have the plate, I just need to drill out the remains of the old bolt and put in a new one.
Yeah I thought exactly the same thing when I saw "radius arm dust cover".
Think I may just get two new ones as they both look a bit long in the tooth.
Anyone know who made the original parts? I've seen some Delphi ones for a reasonable price.
Posted: Mon Sep 05, 2016 9:30 pm
by tonyo
The choice is getting narrower, I've had some decent stuff from Delphi, and a bit of a nightmare with Delpi Wishbone bushes for the Astra (two garages have tried and failed to pull or push them in).
Personally, I'd just throw a pair of complete wishbones on. If the balljoints are old and getting tired, then the other mounts and bushes are too..
From recollection, new balljoints are about a tenner a side, and a complete wishbone is only about twenty quid.. I can't speak from direct experience though, as 'Pete's Parts Store' supplied mine in the end.
The only other thing to remember is if you do the whole wishbone, you need to put new inserts in them before you fit. They are available from GPS still, at about 60p each IIRC..
Posted: Mon Sep 05, 2016 9:52 pm
by James McGrath
How many new inserts will I need?
is 90250709 the right part number?
Posted: Mon Sep 05, 2016 10:29 pm
by tonyo
You'll need four. Googling the part number throws up pictures of the right little things.
Just before I sell you down completely the wrong road.. The V6 doesn't run different parts, does it? All my experience is on a 2.0.
Posted: Mon Sep 05, 2016 10:31 pm
by James McGrath
That's a good point. The wishbones themselves are different on the V6.
