SRi 16v W.I.P. (lots of pics)
- jambo_sri130
Re: SRi 16v W.I.P. (lots of pics)
I think there could be room for another forum here. We could call it "blackmk3cavsrisaloonoc.com"
Sticking feathers up your arse does not make you a chicken!
- Greig Sri
Its not 100% (its about 95%) but Im happy with it for on the Astra.Colorado wrote:Your paintwork is very good.
I got the head rests thinking the bits would be in the seats. So when I found they were not there I wosnt going to let that beat me. So I got hold of a corsa seat to cut the brackets out of it.Gaz wrote:im impressed if there wasn't headrests i wouldn't bother welding in brackets!
OK, you do it then. loljambo_sri130 wrote:I think there could be room for another forum here. We could call it "blackmk3cavsrisaloonoc.com"
Today I got the boost leak fixed, the oil leak fixed and the next stage to getting to bumper painted. When I had the car up off the ground I changed the engine pully, that ive had in the garage for a few weeks.
Heres the fulty parts.
The jublie clip wos at fault for the boost leak. the hose coming from the turbo was sliping off.
The spring clip had rusted and had no spring left in it. It wos on the oil return pipe from the altanator.
The pully had rusted and had buckled.
In the afternoon I washed the car then t-cut and polished it. First time its been polished by me (and anyone) in a long time. Its looking good now,but I forgot to take a pic of it.
It looks great in my opinion i reckon your too critical of your own work. but i know what you mean when you are restoring you want a factory finish
- Greig Sri
I probley am to critical of my own work. I could have painted the Cav myself as my old man and me have all the tools and know how to do, but it wouldnt be a 100% paint job. I like every thing to be 100% when it comes to my cars. More so with the Cav, but its 16 years old so will never totaly 100%..Unless I spend lots more cash on it, but you have to put a limit on it at sometime. With the Astra ive set my standers a bit lower. So I dont spend to much cash on it, some cheap mods and keep it all running and what will do.
Your as bad as i am
- Greig Sri
Well mabe we are. lol
- Greig Sri
Only Cav job this weekend had been getting its tow bar ready for galvanizing. By stripping it in to its single bits and drill holes in the hollow bar. I also did the same to a tow bar that I got this week for the Astra.
When I went to my local frendly scrap yard, I picked up another steering wheel that I will fit in the Astra when I fit a new cd player to it.
Along with the wheel a got a few other bits and pices for the total cost of 'free' to me.
The cav is still waiting to go for painting.
- Greig Sri
Ive got 2 of them now. That one and the Cav has the other on it. Thay are a lot thicker than the Cav one and feel better when driving.
I like them a bit nicer than the standard cav airbag wheel.
- Greig Sri
I wouldnt mind getting the 3 spoke steering wheel from the face lift vectra b. Thay are cool
Ive got the new bumper for the Astra finnished today.
It still need to be polished up in a few weeks with the compound and polishing machine tho.
Very nice job.
- Greig Sri
Colorado wrote:Very nice job.
Thanks.
Foglights are mint too.
- Greig Sri
Yes sure are, thay are not very old. The car I got the bumper from had a lot of cash spent on it before it went to the car brakers. As the boot wos full of the old bits in the new parts boxes. Like every part of the brakes, clutch, clutch cable , starter, fog lights, wing mirror,etc. It would have been a very good car to someone.
Your lucky usually the fog lamps are pretty scarred. Hopefully they wont break it to quickly. My local one had a nice Cav gls in and they had crushed it within a couple of weeks
- Greig Sri
Thats what happens to me most of the time, I miss out on the good stuff. I try to get down to them once a week to have a look at whats new in.Thay have a quick turn round on the cars coming in to going to the crusher. Plus I get a laugh from them, thay all ways have some storie to tell.
- Greig Sri
Update on the cav, Ive got to take it to the paint shop for painting next Friday.
Heres the car stuff ive been up to this weekend.
Went to the scrap yard to get new bits for the Corsa. I needed the power steering rack and the pasanger side hub. Took me 2 1/2 hours to get the bits off. The scrap car was on the ground so I had to take the rack out the top.
Heres the car after getting the parts off, as you can see I had a lot of things to remove first.
The bits I took off.
Then it was the Astras turn. I fitted the new head unit I bought on Thursday and the Vectra steering wheel.
The head unit is going to take a bit of time to get it sused. It has a lot better sound than the old one I had fitted before. The car still has the vaux speakers the now, but not for too long I hope.
Good days work there. And soon your Sri will be where my turbo is in a bodyshop.
- Greig Sri
Its been a long time since I started to do up the body work on the Cav, but after its painted ill be able to see the light at the end of the tunnel. When are you getting your turbo back from the bodyshop?
As is always the case with these things a bit longer than i thought! When the front windscreen was removed there was a bit of corrosion under the top rubber but underneath the bottom edge of the windscreen the metal is wasted away with a couple of holes in it. It turns out that when they renewed the window whoever did scraped all the old sealer of the frame and most of the paint too which is why it has been bubbling away underneath. The piece of metal that forms the screen base is a part that is no longer stocked so it is a case of getting it repaired. The rest of the roof is done ready for priming and painting.
- Greig Sri
Thats just typical of an old car, one problem leads to a bigger problem. I had my windscreen taken out about 18 months and the roof painted at the same time. It needed a new screen for the mot and had a small bit of rust along the top of the rubber trim.
I am glad i found out before the metal had rusted away too much
- Greig Sri
At least its fixable.
- Greig Sri
A wee up date , Ive got the tow bars back from getting galvanised. No more rusting problems with then.
Im going to paint them tho, will stand out a mile if left as is.
The Cav is now at the paint shop, it will be there about a month.
This is it loaded about to go.
