ABS bracket (Vauxhall cavalier)
Falconware
Post by Falconware »
Hi guys, I have Vauxhall cavalier, need to install ABS sys on it.
Actually i have got all parts (the pump unit - Sensors - Looms ) before, but i don't have the unit bracket that i can to connect or install on the right place on the chassis.
the problem is i don't know it beside that i didn't see it before to understand what should can i get it from
So i need some PICs for this bracket to get it.
thanks so much friends
Born to race
Telegram Sam
Re: ABS bracket (Vauxhall cavalier)
Post by Telegram Sam »
I don't know if this is still current after 5 months (?) but if so I will have to replace mine (the mounting bracket) which is broken. It should be possible to get a pic in the course of doing so. The part no I was given for my 90/91 SRi was 90345826 which is the plastic replacement for what was originally metal. Still available in the supply chain.
Yes the plastic part is indeed still available from dealers or even Genuine Parts Search.
From memory they are either about £5 or £7 each.
Part numbers are
90 345 826 and
90 345 827 depending which side you want.
