Page 1 of 9
3.0 V6 Cav
Posted: Mon Nov 23, 2009 10:20 pm
by iancav6
A few shots of my Cav 3 litreV6.
Main aim is to get it as fast as poss down the 1/4 mile.Currently at 14.4@98mph.
I want to keep it a standard looking as possible.
3 litre going in.
New exhausts i'm fitting
New manifold flange i'm making.
Re: 3.0 V6 Cav
Posted: Tue Nov 24, 2009 2:57 pm
by humbucker
turbo wheels look ace. what's the manifold, one you made? good work, look forward to progress
Re: 3.0 V6 Cav
Posted: Tue Nov 24, 2009 6:57 pm
by iancav6
Manifolds are from a Ford probe V6,made of stainless, bought new off the bay for £130.
Re: 3.0 V6 Cav
Posted: Tue Nov 24, 2009 6:59 pm
by Gaz
Your not in the cheshire area are you as turbodan thinks he spotted you?
Re: 3.0 V6 Cav
Posted: Tue Nov 24, 2009 9:49 pm
by iancav6
No i'm in Rugby, Junc 1 of the M6.
I think Dan saw my car at Santa Pod in october?
Re: 3.0 V6 Cav
Posted: Wed Nov 25, 2009 9:04 pm
by Gaz
yea you parked next to our cars, whats the plan with the exhaust next 2.5" system to match?
Re: 3.0 V6 Cav
Posted: Wed Nov 25, 2009 9:11 pm
by iancav6
Already got a Scorpion stainless system all through with a decat, not sure what size it is?
The Probe secondaries are pretty good in that they are equal lengths front to rear banks, where as the std Cav V6 are unequal. Once the primaries are done i'll move on to these.
Re: 3.0 V6 Cav
Posted: Wed Nov 25, 2009 9:16 pm
by Gaz
they tend to be 2" nothing special.
the exhaust design on vauxhalls tends to be made to a budget rather then power, goes to show what can be achieved
Re: 3.0 V6 Cav
Posted: Thu Nov 26, 2009 12:02 am
by Squig
Once again possibly giving egg sucking lessons again but read somewhere manifold pipes should be 110% of cylinder capacity, hope this helps. Allows for best airflow and minimal pressure prior to cat.
Re: 3.0 V6 Cav
Posted: Thu Nov 26, 2009 10:11 pm
by iancav6
There is loads af science behind exhaust pipe design, size and lengths, you could spend ages working out what is best for any engine. I think these pipes are probably too short, an engineer at work reckons 600mm would be about right, failing that go for 300mm which these are.
The sizing is a compromise between being too big which will give you high flow, but low velocity and too small will be restrictive but high velocity. The port size on a V6 is roughly the same area as the 1 5/8 dia pipe in this system so that persuaded me it was about right.Looked at a load of stuff on yankee websites and they would tend to say 1 1/2 was right, but that looked too small to me.
Also much depends on packaging it all under the bonnet, 600mm pipes may be good,but they would end up being more expensive to make. I might look at this though once i've made this set.
However, I think that anything has got to be better than the standard manifold.
Re: 3.0 V6 Cav
Posted: Thu Nov 26, 2009 10:15 pm
by humbucker
you're not wrong, the stock v6 manifolds suck. if you'll excuse the pun.
Re: 3.0 V6 Cav
Posted: Fri Nov 27, 2009 8:58 pm
by iancav6
This is where i have got to so far with the flanges.This weekend i'll remove some of the excess material.
Re: 3.0 V6 Cav
Posted: Sat Nov 28, 2009 9:11 am
by Gaz
Looking really good, i suppose im spoilt having an xe as you can pick up flanges off ebay/forms really easy
Re: 3.0 V6 Cav
Posted: Thu Dec 03, 2009 8:19 pm
by iancav6
The completed flanges and the first pipe tacked in.
Re: 3.0 V6 Cav
Posted: Tue Jan 05, 2010 8:15 pm
by iancav6
Front manifold almost finished.
Re: 3.0 V6 Cav
Posted: Tue Jan 05, 2010 9:23 pm
by humbucker
nice work, but thats a lot of cak on there!
Re: 3.0 V6 Cav
Posted: Tue Jan 05, 2010 10:07 pm
by iancav6
Its only a spare engine I've got on a stand in my garage.But yes,it is covered in cak
Re: 3.0 V6 Cav
Posted: Wed Jan 06, 2010 11:58 am
by humbucker
phew! for a split second i thought you were fitting those shiny new manifolds onto that filthy old lump and then sticking it in the car haha!
Re: 3.0 V6 Cav
Posted: Fri Jan 08, 2010 7:15 pm
by iancav6
The completed front manifold(minus crud covered engine)
Re: 3.0 V6 Cav
Posted: Fri Jan 08, 2010 7:20 pm
by Gaz
very very nice!
Re: 3.0 V6 Cav
Posted: Tue Jan 19, 2010 8:32 pm
by iancav6
Re: 3.0 V6 Cav
Posted: Tue Jan 19, 2010 10:24 pm
by Squig
They look awesome...
Re: 3.0 V6 Cav
Posted: Thu Jan 21, 2010 10:03 pm
by cavalierclaire
Very nice mate.
Re: 3.0 V6 Cav
Posted: Sat Feb 27, 2010 4:28 pm
by iancav6
Finally finished the pipes,hopefully get them fitted next weekend.
Re: 3.0 V6 Cav
Posted: Sat Feb 27, 2010 8:06 pm
by HAIRIBO
Sweet! Fancy making me and Sqiug a set????
