Lowrider Dave's V6
Re: Lowrider Dave's V6
Loving the detail on this one :)
Envoy CDX wrote:
lowrider dave wrote:
DiplomaXE wrote:Looking good dave.
Try the online opel parts cat.
Cant remember the address and am away at the mo.
Tried that, shows three possible options - although i'm not the best at disyphering(?) the catalogue.
What is the rest of your brake system? ATE or BOSCH?
I *believe* it is ATE and I have tracked down the correct part number for the modulator/compensator. Many channel already tried and no luck, will leave in place for the meantime but will keep looking just in case. Himselfunknown is sending me a pair of used ones as backup - that reminds me, have they been posted to me yet??!
I am fairly confident that the parts I linked you to, will do the job.
Worth a note to anyone reading about making brake pipes..... Remember to put the fitting on before you flare it. (Go on Dave, tell us, did you remember ;-) )
planetc wrote:Worth a note to anyone reading about making brake pipes..... Remember to put the fitting on before you flare it. (Go on Dave, tell us, did you remember ;-) )
Aye, seen it done many times. A few where the fitting was put on the wrong way round too.
Oh yes, I remembered! I was in one of methodical moods where I check every stage - doesn't always work like that though!
For some reason my handbrake cable seems to be shorter now as I can't get it to attach to one side of the hub...arse, nothings simple is it?!
Is it snagging on anything? Did you turn the adjuster nut on the cable section that runs along the rear beam?
Pics of the rear beam and routing? could be something simple.
I haven't turned the adjuster and everything looks clear and unsnagged as far as I can tell.I 'll get some pics up if I can't solve it today.
The handbrake video...
*clicky link*
http://www.flickr.com/photos/davekirwin/13270411243/
Got some new handbrake springs...
...and this is why
New Tarox discs and renovated brake callipers
Fitted.
Super89
Post by Super89 »
Looking good Dave, I had to buy new springs for mine too :)
Loooooking snazzy
Big thanks to Pete for stopping by on Sunday and sorting out the troublesome handbrake cable problem - legend.
DiplomaXE
Post by DiplomaXE »
Pleasure Dave,
you have lots of shinyness under the back of the V6 there..
lovely stuff
:lol: What are you, a magpie?
Looks pretty good that m8 :)
chris.h
Post by chris.h »
looks good there
Cavalier342 wrote::lol: What are you, a magpie?
I resisted the urge to chrome plate the rollbar and a batch of bolts though!
Bolted wheels back on and dropped it back down off the stands. Started well after being idle for a few months. Rear hose popped off and wee'd petrol on the floor so fixed that with a new clamp. Just have to bleed the brakes then I'm ready to roll again. :)
Intend to go to the Retro Rides event at Rockingham April 21st.
Good news then. I fired up my auto on Tuesday after a month stood up, ran fine but 3 HT leads decided to pop out :lol: Seems like these Cavaliers just do not want to stand around doing sod all.. And they let you know about it!!
Yanayaya
Post by Yanayaya »
I'm loving those break discs there. Oosh!
Finally got round to bleeding the brakes, but the handbrake has suddenly become very loose! Can't see whats caused it - grr, wanted to go out on Monday.
Handbrake flopping about and loads of slack on the cable - I think something may have broken, doesn't look like I'm going to make Retro Rides event at Rockingham on Monday after all. :(
Check the cable at the wheel hubs, it may have snapped there or just needs adjusting...
