Plans changed again tonight.
The expanding reamer had not arrived yet, so nothing done on the crankshaft flange tonight.
This picture looks worse than it is.
There is some chisel-marking on the flange, but about 95% of the visible damage is on the remnants of the outer shell.
___________________
So instead, I looked at the induction system.
First - fitting of the black Mikalor jubillee clips - 32-50mm.
From memory, the tubes are 40mm diameter.
You will see in the images, that I have also fitted the Bosch injectors with new retaining rings and seals.
And the fuel feed rails.
Bizarrely, the injection manifolds use 1/8" thick plastic gaskets (?) between the manifolds and the heads.
No paper, card or gasket sheet.
I used non-hardening seal paste between all the layers to avoid any leaks - maybe I am being over-zealous, but I don't want to start faffing with induction leaks a few months into the future.
So -
Left manifold assembled...
And right manifold assembled...
Final actual job, was to put a new gasket on the front left manifold blanking plate.
I would like to start fitting the exhaust, but I need to save up for a pair of push-rod shields first.
Both originals are rotted. The right one fell off on the way to the unit a few months ago.
Right push-rod tubes visible because the shield fell off.
The left one is hanging on for grim-death.
The left cover rotted and swollen before it's journey to the unit.
________________________
I looked at the injector and sensor loom wiring.
It appears that I need to fit a wire for the blue charge exciter wire on the alternator.
And I will need to check the DJ loom.
I have spotted an extra 2 pin connector for the Maestro digi-dash temperature gauge sensor.
Correct wire colours, and fits perfectly.
_____________________________
In good old Robsey fashion, I could not be fussed bringing home the loom for rectification / updating.
Further checks through the loom bag, and a box with the original DF loom, reaveals that I appear to have two ignition amplifiers and two digital idle controllers.
I do like to have spares.
And for my own info... a green label coil.
There are two versions - green label and grey label.
Something to do with internal resistances of the ignition system.
More fun next Tuesday evening
