At least you have made a start.
Getting motivated to start again is usually the hard part.
Pretty impressive considering how bad the cold affects you.
![Thumb :thumb](./images/smilies/thumb.gif)
I'm undecided weather or not to keep the imboliser that was fitted to this van after it got stolen just after it was new. ( It still caries the screw drivered door lock to this day). It has an electronic key fob but has apparently been playing up for a while, if I can't sort it I'll definitely ripp it out and build my own.Robsey wrote:Oh I do like new parts.
Boredom???
How did that happen.?
Not much chance of that at Robsey Manors.
All work and no play these days.
And no decent weather - pah!!
I did the same with my Cavalier.
But I used an air con switch back in May 2017.
[ Image ]
Thanks, very nerve wracking cutting into a new bumper, particularly as it was hard to find a suitable edge to act as a datum point, although it wasn't quite so cold in the workshop, probably about 5 degrees,just wish there was room to get the van inside.ilovedmymantas wrote:Nice work on the bumper, especially in this weather!![]()
I wish I had a height adjustable workbench like yours, come to think of it I wish I had a workbench
Yes I did have a complete panel, but it has to be spliced into the transmission tunnel anyway, and it was only the edge of the existing floor that was rotten. At least this way I keep some of the original van. Also the Klokerholm panel feels slightly thinner than what vauxhall fitted.cavalier1990 wrote:Looks like a decent enough fix, I find that sometimes, the weld just seems shitty, doesn't want to flow, other times it works really well. I think welding new metal to old, even no matter how good a nick the old metal is, doesn't make for a decent weld, as it would new to new metal.
Did you not have complete klokkerholm floor pan repair panels for this?
That's some very good points, I've only ever seen welding rods kept warm, but I guess it's logical the same applies to welding wire. For years I've kept a couple packets of silica gel in the bottom of the welder under the roll of wire.ilovedmymantas wrote:Welding this time of year is usually messy, I think it's down to the moisture from the air.
It's been over forty years since my welding apprenticeship and I've forgotten most of what I learned as I haven't been welding for years![]()
I do remember the 'stick' welders at the works putting the rods into an oven(60 degrees iirc) to remove the moisture from the flux.
With that in mind I always baked the flux cored wire for the mig before use and used a hot air gun to dry out the prepared edges of the bodywork, definitely worth a go![]()
As someone who's had to buy a few recentlythe klokkerholm panels do feel thin, perhaps their reputation is based on fitment? I've had a couple of other panels in the past with that were shocking!
matt
