whats the best tracking
- joe cavalier sri
im thinking a good advers camber for my rear axel and what would be the best to track my front wheels up to its lowerd 60mm its on my sri cheers
Re: whats the best tracking
Camber is fixed on the beam axle
you would have to fit eibach camber shims
Do they shim the hub pie? I assume they do cos I can't see where else you would shim it?
yes
iirc they go between the hub and beam
ivew never usewd them so not to sure
but as you say they can only go one place
Troy has these fitted on the back of his cav. They do fit behind the hub yes. Funny little things they are but they do the job.
- joe cavalier sri
how much and where can I get them from ? whats the best tracking for the front of the sri lowerd 60mm and the best adverse camber with the shims fitted ?
You cant fit them shims on the front. Well unless you put them behind the wheel maybe.
as dan says front are fixed unless you want to start modding you top mounts etc
only the back can be camber'd
and 60mm drop shouldn't need tracking tho
- joe cavalier sri
ok cheers pie was wondering where can u get the shims from ?
Ebay and google, you should try them some time
http://www.ebay.co.uk/itm/Eibach-Rear-C ... 3f01d5ba0a
